12-10-2017, 01:06 AM | #1 |
Drives: '15 SS Join Date: Sep 2012
Installed a CAI intake on a my 15 SS BUT
The lid was a PITA, literally my lower back hurts from bending for so long anyway in order for me to close the lid i had to take out the weather strip, tuck the lid underneath and then put the strip back on except for this part wont go back in. This was the only way i could close the lid and tighten the screws. Did i do something wrong? Anyone else have problems with this?
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
12-10-2017, 01:08 AM | #2 |
As you can see the lid prohibits the strip to go back in
12-10-2017, 10:34 AM | #3 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
installed CAI
Hopefully this picture will help you out with fitment. I know the lower left 1/4 turn screw is a pita to screw in. This picture was pre-painting the tube lol
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
12-10-2017, 10:54 AM | #4 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Z-28 CAI. NO BRAINER. NO PROBLEMS. WHATSOVER. Who needs the headaches?
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
12-10-2017, 11:39 AM | #5 | |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
12-10-2017, 12:18 PM | #6 |
The z28 intake looks clean. I was thinking of getting it but went with CAI since everyone on here praises it. I had roto fab in my v6
That looks perfect. Thanks ill keep trying
12-11-2017, 07:11 AM | #7 |
Thank you. All I did to install the lid is tip the front edge a slight angle slide it under the weather striping. Then slide lid to the right so it goes between the "pinch weld" on the fender and turn the screws a 1/4 turn to lock it down.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 Last edited by Stewart; 12-11-2017 at 11:01 AM. |
12-11-2017, 10:51 AM | #8 |
Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
Sorry to thread jack, but it's always so hilarious on here. Many people rip K&N for their intakes, but praise the Z/28 intake. Guess who engineered, designed and developed the Z/28 intake? Yep, K&N!
Good luck OP!
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
12-11-2017, 12:43 PM | #9 |
Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
I had no problem as well as long as you do what is outlined above. Easy as can be.
12-11-2017, 05:32 PM | #10 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
And other makers also make intakes for Chevy "Stock" performance, Actually Vararam was the one making the intakes for the COPOs and well once they had a promising dual bowed long runner intake manifold they were developing but it never quite got produced after waiting and waiting for them to patent it and they called it the VRX....... it faded away and changed to just a cold air intake for nomenclature.....But their cold air OTR over the radiator intake was the best for a 2010 for a long time with being able to tilt the radiator to allow air flow giving it some ram air with its design.
Theres Rotofabs a lot like the z-28 go figure.... Different styles look more plastic to some though; and holding the lid at the angle to slide it under on the fender side first is what I always do with my CAI. Lets face it our stock air box..its hideous.....anything is a improvement. Some of the nicest air boxes I have seen on here were all CAI with the lids laser cut to make shaped artictic stuff....LOL you can CNC plexiglass to great effects..then add some lighting.. to a dragon or a eagle or what ever. But given the styles available and costs I am fairly certain I could adapt my airbox and scoop to a Supercharger and others may not like that so much or function so well. Old pic but you can see my edge is tucked under the seal front and side. You may need to tweak it making it have a lower mounting point
12-11-2017, 10:15 PM | #11 |
Hey guys thanks for the tips. I havent had time to adjust the lid (i know i know) due to the fires and just super busy with work. But man i honesty dont hear a difference with this intake
12-11-2017, 10:18 PM | #12 | |
12-12-2017, 06:20 AM | #13 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
had zero problems with my k&n
12-12-2017, 03:20 PM | #14 | |
The new Vararam CAI is called the DRX. The intake manifold that never was: the VRX.
