Old 12-06-2017, 02:14 PM   #1
Boo
Drives: 2017 ZL1 A10 Nightfall Grey
Unplugging negative terminal
When installing a CAI directions say to unplug the neg battery terminal. Is this truly necessary? Ive read where people just ignored this directive and all was fine.
Reprogramming all the personalised settings doesnt sound fun. I've read this is for any reason from personal protection to the maf sensors recalibrating. Any feedback is greatly appreciated! Thank you.
Boo is offline   Reply With Quote
Old 12-06-2017, 02:16 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You really don’t lose any personal settings when you disconnect the neg cable. The most you will lose is the HUD will be a little higher than possibly where you custom set it. And the windows will need to be re-indexed by rolling them up and down once...But all your radio stations, seats, etc. don’t go away when you disconnect the power.
Old 12-06-2017, 02:22 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
The ECM will adjust either way...just like driving at altitude. Of course the ECM is forced to recalculate every time the engine is started and the entire time the engine is running. What if you trailered the car from New York, New York to Denver, Colorado? I know that is more of a MAP sensor thing but both sensors will adjust according to the moment. Disconnecting the battery only puts all of the "learned" categories to "0".
Old 12-06-2017, 02:30 PM   #4
Boo
Ok thank you both. I really thought i was going to spend an hour reprogramming my settings...ive heard radio issues too. It sounds like i really dont have to unplug the neg anyway though...
Old 12-06-2017, 02:32 PM   #5
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I didn't disconnect mine. Nor on my '13 ZL1, nor my '10 SS. In this case it's just another lawyer CYA step. Just be careful with the MAF sensor.
Old 12-06-2017, 02:38 PM   #6
Boo
Ya that makes since. Ive actually installed it without unplugging but im putting it back on now after my first oil change. So i figured i might unplug as directed to see if there is a performance difference. It sounds unnecessary though.
Old 12-06-2017, 02:47 PM   #7
Burly
Burly's Avatar
I recommend disconnecting battery when doing this, better safe than sorry? I have done this at least 6 times for mods(2 CAIs, ported throttle body, and connecting wiring for cutouts). The only thing I’ve found is the outside temperature reading shows dashes until driving for 15 minutes or so. Didn’t loose any radio settings, seat memories or anything.
Only takes a minute with a 10mm socket.
Burly is offline   Reply With Quote
Old 12-06-2017, 03:22 PM   #8
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Disconnecting the negative terminal is standard. It isn't always necessary. But it doesn't hurt. I didn't disconnect mine...I don't think. Maybe I did. Who knows? I say play it safe and disconnect it. It'll only add an extra 38 seconds to the entire install.
Old 12-06-2017, 03:29 PM   #9
Boo
Ok i will. Thanks again for all of your responses
Old 12-06-2017, 04:51 PM   #10
SoCal Racer
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1
That's good info, ty. In the "old days", I would lose everything like most people are afraid of. Time wasted just setting all of my radio stations lol. Good to know that is no longer the case
SoCal Racer is offline   Reply With Quote
Old 12-06-2017, 05:20 PM   #11
Boo
Ok i did it...
So all is well. The onlt things that have been lost are my performance times from indash performance timing. My 3.5 0-60 my 7.1 0-100 and my 11.2 1/4 mile are all gone! I am devastated and feel the need to immediately go out and record them again if not better... DadGommnit i love this Fn car! You know the best is driving around in track with manuel shift on...cruising in 3rd at like 3500rpm and just goosing the trottle...its more fun than a 6speed to me...rifling through all those gears...my wifes gonna divorce me but hey....what a car! Thanks again for all that responded!
Old 12-06-2017, 07:06 PM   #12
1roadking
Drives: 2017 ZL1 silver A10
Hammer down baby��
1roadking is offline   Reply With Quote
Old 12-07-2017, 01:08 AM   #13
Locker
My job is primarily electrical work and troubleshooting. We always remove power when repairing/replacing sensors because they are almost always connected to sensitive control boards. All it takes is a short on the sensor wiring and you can easily burn the pins on the board where it connects. This is not done to protect the sensor as it is easily replaceable, it is to protect the expensive and difficult to replace and reprogram control modules. Better safe than sorry in my opinion.
Locker is offline   Reply With Quote
Old 12-07-2017, 07:57 AM   #14
Stephen12ZL1
Drives: '21 ZLE A10
understood but the MAF connection doesn't have power unless the "key" is ON. Obviously, disconnecting the negative terminal is the best way but not entirely necessary.
