Old 12-04-2017, 01:16 PM   #1
NSLRedHot
Drives: 2016 SS Red Hot
Dealer Murdered My Rear Differential!!!
I took my 2016 SS in to the local dealer to have the rear differential fluid replaced after taking it to the track (as recommended in the owner's manual). They replaced the fluid and the next day there was a horrible rubbing/groaning noise coming from the back end. I took it back to the dealer and they realized they put in the correct fluid, but did not add the lubricant additive that they were supposed to. They put in the additive and it helped a little. I took it back a third time and they swapped out the rear diff fluid with extra lubricant this time. It was better, but still not right. Still groaning and the rear tires chattering in tight turns. It is now at the dealer getting a whole new rear differential put in. Really? is it that hard to put the correct fluid in the first time? Worst of all, the service manager told me he will not refund the money that I originally paid to have the rear diff fluid exchanged!!! :
NSLRedHot is offline   Reply With Quote
Old 12-04-2017, 01:30 PM   #2
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
It is my understanding that the current GM diff fluid now contains the additive. Sorry you're having the problem.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 12-04-2017, 01:33 PM   #3
JT58
Drives: Former 2016 Camaro 1LT
Another horror story to add to the list for me and why my cars do not go to the dealer unless is is something catastrophic or so obviously wrong. I do all of my own maintenance period.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 12-04-2017, 01:44 PM   #4
m4nat
m4nat's Avatar
Wait when you say chattering from the rear tires what do you mean? Do you mean that when you turn left and right hard at low speeds the tires don't like it? I thought this was just because of me putting wider tires on the car (305s). At low speeds when I turn left or right hard, (like pulling out of my driveway and turning hard left or hard right) my rear tires don't turn super smooth, they sort of chirp. Is that something that could have to do with the rear differential?
IG: @manat.0
m4nat is offline   Reply With Quote
Old 12-04-2017, 02:15 PM   #5
SSDanny
Drives: 2017 Camaro SS M6
Maybe an alignment issue, not the width of the tires much.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
Old 12-04-2017, 02:20 PM   #6
m4nat
m4nat's Avatar
I think it is a tire issue, because when I had 275s I did not experience anything like this. Will be getting an alignment done soon, thanks man
IG: @manat.0
Old 12-04-2017, 02:23 PM   #7
born-to-fish-
born-to-fish-'s Avatar
Drives: Fifty 2SS Vert
Every muscle car I've owned with a Posi-trac differential had a slight REAR wheel chatter when turning sharp at low speed.
born-to-fish- is offline   Reply With Quote
Old 12-04-2017, 02:43 PM   #8
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
Ackermann steering chatter is different from what OP is describing.
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
Old 12-05-2017, 07:00 AM   #9
17txcamaross
Drives: 2017 Camaro 2SS
Even just changing from 275 to 305 tires an alignment is needed.
I had my car aligned following lowering my car and put it in perfect spec. Two days later my wheels showed up. put them on and realigned. Alignment shop showed the car was slightly out of alignment.
17txcamaross is offline   Reply With Quote
Old 12-05-2017, 07:11 AM   #10
fastball
Drives: 2017 Camaro 2SS 6MT
Tell him to either refund your money or you'll give them all zeroes on the service survey you will receive in the mail. They take that stuff seriously.
And if he doesn't refund you, give them all zeroes.
fastball is offline   Reply With Quote
Old 12-05-2017, 08:00 AM   #11
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Since the correct fluid already has the lube added they put the wrong fluid in.
craigss50 is offline   Reply With Quote
Old 12-05-2017, 09:43 AM   #12
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
Send a message via Yahoo to wavsine
Isn't this covered by the powertrain warranty?
wavsine is offline   Reply With Quote
Old 12-05-2017, 10:54 AM   #13
Ruebernard
Ruebernard's Avatar
Drives: 2017 GRT 2SS/RS M6 Vert
And the dealer is making good by replacing the differential. I assume they are eating the cost...so why try and stiff them for the cost of the initial visit?
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
Old 12-05-2017, 11:03 AM   #14
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Dealers don't "eat the cost" of warranty work, the manufacturer reimburses them for time and materials. That's how they MAKE money.
The fact that they completely screwed up the service which caused multiple repeat visits, multiple days without the car, and customer frustration is *exactly why* they should be refunding the money spent for the fluid swap. Oh, and the fact that they obviously did it wrong and therefore shouldn't charge in the first place. That's pretty obvious to me, they wouldn't keep my money.
S2K+1LE is offline   Reply With Quote
