12-04-2017, 11:33 AM | #1 |
Power Steering failure
Went to pick up the Camaro Saturday after turning it in for power steering failure and the rear end grind. The dealer replaced the differential, but only found a C0800 low power failure for the PS. They could not duplicate the PS failure. While driving home, it failed again, so I returned to the dealer. It failed 2 more times and only once did the Power Steering Failure - Drive carefully pop up. This cars been to the dealer quite a bit. It dropped some valves and the heads were replaced, differential replaced, and now 2nd instance of PS failure.
12-04-2017, 06:14 PM | #2 |
Drives: 2016 Camaro 2SS Black.. Join Date: Jul 2017
Sorry to hear that your having these problems with your Camaro. I'm in the same boat. Ive had the rear differential replaced, rack and pinion replaced, exhaust replaced. Rear axle shafts replaced. Seems like these cars have a lot of issues. Good luck with it though.
12-04-2017, 11:55 PM | #3 |
Drives: X-15 Velocipede Join Date: Mar 2008
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
12-05-2017, 04:08 PM | #4 |
I talked with the tech, he stated he did the TSB and checked.
12-05-2017, 04:20 PM | #5 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Which TSB is it? You have a Nr.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
12-08-2017, 03:31 PM | #6 |
TSB #17-NA-115, mentioned in other PS thread. Dealership got the go ahead to replace the torque sensor.
12-09-2017, 12:11 AM | #7 | |
Power plug fully seated? Yes. Then: Torque sensor intermittently defective, some long enough to set codes, some not. u
12-11-2017, 03:41 PM | #8 |
It took them at least 4 days to figure out to read the bottom line I guess. The part was supposed to be in on Monday. We will see how long it takes to install and probably needs an alignment.
12-11-2017, 10:52 PM | #9 |
It's lucky they came to that conclusion.
Usually they want a hard failure, or codes, which is ridiculous and dangerous. You have a good technician. .
02-11-2018, 06:16 PM | #10 |
All,
It went in for a third time. I think the issue was resolved. A ground on the front drivers side of the engine block was loose. So far so good. |
02-11-2018, 06:20 PM | #11 |
Drives: 2018 Silverado Z71 TxEdition Join Date: Dec 2017
this sound your hearing coming from the rear diff, is it like a low howling sound? i'm noticing something as i turn a corner while i have the rear seat down. mainly for more bass, but i'm hearing a low humming noise while i'm making a turn. thx
p.s. i've also had the rack replaced for my steering issue. anyone have a column replaced? thats the issue i'm having now is they cant get one!!! |
02-11-2018, 07:16 PM | #12 | |
Engine ground takes out the PS. I think that bad ground could be contributing to slow cranking issues. Keep your fingers crossed
02-12-2018, 10:13 AM | #13 |
Drives: 2018 ZL1 M6 Join Date: Dec 2017
[QUOTE=camaro5;10073898]Man, that is some weird stuff...
Engine ground takes out the PS. I think that bad ground could be contributing to slow cranking issues. Keep your fingers crossed You drive a 2019 Camaro??? |
02-12-2018, 11:24 PM | #14 |
