Old 12-01-2017, 11:39 AM   #1
parish8
Drives: 17 SS a8
Stock bottom end hp limit
I just saw procharger post up about a sbe lt1 over 900rwhp. I saw another guy over on the corvette forum post about being over 900rwhp.
Can a sbe lt1 really live at these levels. If so it is time to turn it up. I wouldn’t be devastated if I blow it up but I don’t want to turn it up to a point where it will blow up for sure.
Old 12-01-2017, 11:47 AM   #2
ShizzySupra
Drives: 16' Camaro 2SS
Weren't those LT4's? Don't think any SBE LT1 has seen a true 900rwhp....
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 12-01-2017, 06:19 PM   #3
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Aren't you already well above what the reported limit of the SBE is??
If not i need to do some SERIOUS turning up haha.
Been wary because of how much shit everyone is saying I should touch to survive at anything higher than 650whp
cam, piston, rods, valvetrain, fuel, axles, driveshaft, fuuuuuu
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol //
(purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills)
// 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap //
exxit is offline   Reply With Quote
Old 12-01-2017, 06:28 PM   #4
exxit
Correct me if I'm wrong our LT1 goes something like this
550-580 (some at 600whp out of the m6) Bone stock block with a blower.
Add Cam and more boost, 650 to 660whp (at piston limit)
Add LT4 parts + pistons (hpfp, low side, intank, injectors) go e85 750 - 800whp
To take the next step the rods come in question
At any point in the game you can add meth to squeeze a few more ponies out of each stage.
Correct me where i ****ed this up. Every builder seems to take a unique path towards high HP in these cars and it gets exhausting to keep track of it hah
Old 12-01-2017, 07:04 PM   #5
Swagger
DaWolfOfAllStreets
Drives: 17 C Coupe, 17 1LE, 16 Scion iA
If thats the post here by Procharger then that is my car and its a LME 416 stroker short block and cammed (unported heads with updated valve train components) But not a stock bottom end at all. That being said I have seen some 800-900whp stock bottom end Vettes. The rings are the major weak link, I feel like 700-750whp is the absolute limit with fueling
Swagger is offline   Reply With Quote
Old 12-01-2017, 07:06 PM   #6
parish8
Drives: 17 SS a8
Fuel is another issue. I have plenty of fuel and octane available.
The 3 set ups I am thinking of may all be lt4’s but I didn’t think so. I was hoping this post would get a response from some of those people pushing it. I will start asking them individually.
Old 12-01-2017, 07:28 PM   #7
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
The sbe LT1 is no different then Gen IV and Gen III LSx engines when it comes to materials used. The biggest issue I’ve seen with guys blowing the sbe up is the lack of re-gapping the rings for the boost/power adder they’re using. Just like the previous Gen’s, the rings need to be addressed in order to make big power.
This is where the conundrum comes in....do you pay a shop to dismantle your engine, put fresh rings and bearings in it with gapping the rings according to where you want to be power wise, OR do you add the $900 to get forged pistons while you do it? Most guys say for the added insurance, you buy the pistons.
Our engine will live to the same power levels as an sbe LSx if you do the same things that were done with the previous Gen engine.
It really is engine building 101.....you can’t make a 450 hp build survive at 900-1000 hp and expect it not to break parts.
Now take the same 450 hp build, and gap the rings for more boost so that they don’t butt the rings together under higher chamber pressures, you then have an engine capable of way more hp.
It all depends on if you want to say you have an sbe or not....
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 12-01-2017, 10:20 PM   #8
laynlo15
Drives: 2022 Lt1 A10
I'm at 670 and waiting for my injectors and I'll be porting the heads and manifold hoping for about 740 and about 16 lbs of boost and still on stock block with no other internal mods. Parish is above that now.
Old 12-02-2017, 05:52 AM   #9
Swagger
DaWolfOfAllStreets
https://www.corvetteforum.com/forums...ion-build.html
Looks like this LT1 Vette went all the way there and eventually the factory rods failed him. The motor did have drop in pistons that were not the cause of destruction. But the block was destroyed
Old 12-02-2017, 08:21 AM   #10
ShizzySupra
Agree on most points but the LT1 is also a full point of compression higher as well. If I am opening up the bottom end its getting pistons/rods.
Old 12-02-2017, 09:17 AM   #11
parish8
Drives: 17 SS a8
I did a little more research.
the one corvette over 900rwhp on sbe was an ls3 car posting in the 7th gen section.
cleetus is at 840rwhp. pretty sure he is sbe and not lt4. he is also a stick and not much over where I am at.
the 3rd car is something procharger mentioned in the cleetus thread. it is over 900rwhp on a sbe but they didn't mention if it was an lt1 or lt4. hoping they will post up.
I am thinking I probably don't have a lot of room to turn it up. the reason I ask is this winter I am working on my 60'. converter, 15" wheels and 9". it will be awhile before I can touch the engine.
Old 12-02-2017, 09:22 AM   #12
DFW1LE
DFW1LE's Avatar
I was under the impression that ring gap, possibly wrist pins, and the tune will play a big role in how far you can go?
Old 12-02-2017, 09:55 AM   #13
Swagger
DaWolfOfAllStreets
Rings/Gap for sure, I would say pistons are worthwhile if you are already in there.
Old 12-04-2017, 09:00 AM   #14
Cdflyer
Cdflyer's Avatar
This is exactly why everyone says 700whp. If you’re going to do rings/gapping, you might as well replace them as it’s safe insurance. There’s no reason just gapping them wouldn’t make them live though.
