Old 11-30-2017, 11:36 AM   #1
ppiamp
Drives: 2018 Camaro 2SS Auto Hyper Blue
Full range and Flat signal from Bose Doors?
I have a 2018 2ss auto with Bose:
1.Does anyone know if the signal after the Bose amplifier, that is going to the left and right doors is full range (20Hz to 20,000Hz)?
2. If it is full range is it a flat signal or does it need to be EQ?
Thank you.
ppiamp is offline   Reply With Quote
Old 11-30-2017, 01:27 PM   #2
lDejavul
lDejavul's Avatar
Drives: Camaro SS
None of the speakers are full range. They are all EQ'd. The closest to full range you get is the back door speakers. The front door are just bass, they are the best sub freq you will get. The back shelf speakers are bass but not as much as the front doors.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 11-30-2017, 02:04 PM   #3
ppiamp
I am just looking for a clean sub woofer output from the Bose system.
So if I tap the signals to the door from the amp, Left + Right and mix them, I will get a subwoofer signal? I assume this is approximately (20hz to 100hz)?
Is this sub signal flat?
Old 12-01-2017, 05:53 AM   #4
ecko04
Drives: Too many to list
Thank you.
1) The speakers themselves are full range, meaning that they are capable of 20Hz - 20KHz. However, keep in mind the speakers, though not limited technically, cannot produce the full range of sound.
2) No where near a flat signal. This is a Bose system, the signal is not flat by any means. It is EQd to hell and back.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
intall, stereo, subwoofer
