Old 11-28-2017, 11:49 PM   #1
Bowty2SS
Bowty2SS's Avatar
Drives: 2017 Camaro 2SS A8
Cam swap components
Does anyone know all the necessary components needed for a cam swap? How many LS7 lifters do I need? Do I need to purchase ARP head bolt or stud kit? Want to get all that I need when ordering but want to get the right stuff. A breakdown of all parts needed would be amazing. Also as a side note i will be doing the BTR stage 2 cam. Will I need a converter?
Bowty2SS is offline   Reply With Quote
Old 11-29-2017, 12:37 AM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
You should get a full cam package, go through Texas speed so you can see everything you need, you will need lifters, it’s up to you to decide on if you want to change all 16 as well as if you want ARP head bolts, you need gaskets for headers, Valley cover, heads, need a afm/DoD delete kit, push rods, I went with a trunion upgrade kit, also depends if you want +32 fuel lobe on your cam and if so you need a lash cap. Uhmmmm think that’s about it lol? Cost me a good ol 1500 for everything, tuner wants to charge $1600 sooo I’m doing the install tomorrow myself and will try and do a decent picture heavy write up for everyone
MP3BOOSTED is offline   Reply With Quote
Old 11-29-2017, 12:42 AM   #3
FATTEMUNK
FATTEMUNK's Avatar
Drives: 600whp 2016 C63 AMG/ 2018 SS 1LE
Is it necessary to buy a valley cover? On TSP's website you can just get plugs, but I read that a member had some part of his fuel system burst up and the valley cover saved his supercharger. A maggie build i think.
FATTEMUNK is offline   Reply With Quote
Old 11-29-2017, 12:43 AM   #4
MP3BOOSTED
MP3BOOSTED's Avatar
https://www.texas-speed.com/p-4532-t...t-package.aspx
https://www.texas-speed.com/p-5443-t...elete-kit.aspx
This is everything you need
Old 11-29-2017, 12:44 AM   #5
MP3BOOSTED
MP3BOOSTED's Avatar
No yourstock cover is just fine, I meant valley cover gasket. That isn’t even necessary but I mean if your changing all gaskets then why not 😎
Old 11-29-2017, 12:46 AM   #6
MP3BOOSTED
MP3BOOSTED's Avatar
I just read the rest of your post, that’s crazy, probably his build? I mean if you go with a power adder I’d prbably get it? Not quite into spending over $300 for a Valley cover that says KATECH on it, especially for something that you’ll never see unless you take your manifold off, im sure their is a science to it and will get many people commenting their thoughts on it but yeah I didn’t get it.
Old 11-29-2017, 04:52 AM   #7
PRAY
PRAY's Avatar
Drives: 2016 2SS
This is everything that comes in my custom cam kits. Price starts at $1,250 and go to $1,400.
PRAY Performance custom cam kits:
Custom cam w/ 32% fuel lobe
Fuel pump lash cap
TSP spring kit (springs, seals, seats, retainers)
Push rods
16 LS7 lifters
LS2 lifter trays
Head gaskets Stock GM (Cometic .040”x4.100)
Head bolts
Crank bolt
Cam bolt
Front seal
GM RTV
Comp phaser limiter kit
TSP 0* phaser block
TSP Trunion kit
TSP oil block off plugs
Exhaust gaskets
Old 11-29-2017, 09:29 PM   #8
FATTEMUNK
FATTEMUNK's Avatar
Are trunions as needed on the lt1 as they were on the ls3?
Old 11-29-2017, 09:30 PM   #9
FATTEMUNK
FATTEMUNK's Avatar
Yeah that's why I'm unsure. I don't want to spend 400 on something that I never see and is not necessary. But I'd rather she'll out 400 now rather than a new supercharger later
Old 11-29-2017, 09:32 PM   #10
Bowty2SS
Bowty2SS's Avatar
Pray do you have a sound clip of your cam?
Old 11-30-2017, 04:29 AM   #11
PRAY
PRAY's Avatar
Drives: 2016 2SS
I can't get it to upload here. Click on my FB link at the bottom. It is on there.
Old 11-30-2017, 04:30 AM   #12
PRAY
PRAY's Avatar
Drives: 2016 2SS
Yes, I saw no difference in the LS and LT trunions. Same crap as before.
Old 11-30-2017, 09:41 AM   #13
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Plenty have run cam setups on stock oem LS rockers over the years with no issues. Especially low mileage units...However it is highly recommended to upgrade the Trunnion's for piece of mind. I would do a bushed Trunnion if you do it.
Old 11-30-2017, 11:35 AM   #14
Bowty2SS
Bowty2SS's Avatar
Does your cam require a converter change. Love the sound btw!! Also is your custom grind cam from TSP?
