Old 11-28-2017, 06:22 PM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Part number help please!
While pulling my engine, I accidentally smacked one of the nipples for the clean side catch can/ breather... whatever it's called. I have spent hours on tgmpg site tying to find it But can't. If anyone (maybe our community parts/ dealer people) has a part number I would greatly appreciate it!
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 11-28-2017, 11:52 PM   #2
JaxChris
The part number is the 8 digit number right on top of the oil separator. It should say 12672470.
It isn't available from online sales. You'll need to visit a dealer to order or try calling one of the GM part selling sponsors directly. I checked the major ones on here for you and none have that part number on their sites. The part is made by AC Delco, but I couldn't locate any online purchase option for it.
Good luck.
Old 11-29-2017, 03:19 AM   #3
brettman
Drives: 2016 Camaro SS
http://www.camaro6.com/forums/showthread.php?t=512655,
Do a search, Joe found it cheaper.
brettman is offline   Reply With Quote
Old 11-29-2017, 03:20 AM   #4
Dubchitts
Dubchitts's Avatar
Good luck.
Dang that sucks. I'm sure that means I'm about to get screwed on the cost. Thank you for the info! I'll contact my local dealer today.
"Spitfire" 427ci
Old 11-29-2017, 03:25 AM   #5
Dubchitts
Dubchitts's Avatar
I'll keep this in mind in case I still can't get it. But I'd rather replace it now than later while my water pump is already off. (One of the bolts is in an otherwise tough spot if the water pump is installed)
Thanks for the info!
"Spitfire" 427ci
Old 11-29-2017, 03:30 AM   #6
brettman
Joe's was repairable, there is other part numbers to replace it.
Use that HP tuner yet?
Old 11-29-2017, 03:35 AM   #7
Dubchitts
Dubchitts's Avatar
Quite a few times! Should have another tune process this spring for it!
"Spitfire" 427ci
Old 07-09-2020, 08:18 PM   #8
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
hey I know this is late but I am having this same issue and just wanted to know what codes were popping up for you when you were dealing with this. for me I have these 3 codes below that pop up and I wanted to know If any of these relate to it?
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
