Old 11-28-2017, 05:38 PM   #1
SSDanny
Drives: 2017 Camaro SS M6
Doors automatically lock and unlock?
I'm wondering if anyone has some experience or maybe some input regarding my doors unlocking and locking by themselves.
Basically, my vehicle was in an accident two months ago where I was hit on the drivers side, mainly the door. I got my car back last week, and have noticed that after I lock the doors with my remote fob, they will unlock, lock, and unlock.
Of course, this is due to the damage on the door. It seems, however, that this is some security measure the car does to not remain locked in the car in the case of an accident? Or are the locking mechanisms broken?
Yes, the insurance is going to send someone out to take a look at it.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
Old 11-28-2017, 05:53 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I never use the key fob for locking or unlocking my car. I use the button on the handle to unlock and the door switch to lock. Read up on how thieves can steal your key fob signal.
dpevans is offline   Reply With Quote
Old 11-28-2017, 06:47 PM   #3
my1stchevy
Drives: 2016 Camaro HBM 2SS NPP MRC
I agree with the above regarding the key fob signal. If the accident was 2 months ago and you just got it back last week what work was done to it in that timeframe?
my1stchevy is offline   Reply With Quote
Old 11-28-2017, 06:51 PM   #4
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
I set my car to lock itself after I step out of it and then use the button on the handle to unlock. A friend recently has the same issue with yours but his is a 5th Gen. He hasn't solved the issue either but he bought the car used.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey.....
1100 Status - 08/17/2015 : 2000 Status - 09/28/2015
2500 Status - 09/29/2015 : 3000 Status - 09/29/2015
3000 Status - 10/19/2015 TPW 11/9
3800 Status - 11/04/2015 Seq: 122808
4300 Status - 12/17/2015 (Charlotte, MI)
4200 Status - 01/08/2016
4800 Status - 01/14/2016
5000 Status - 01/19/2016
6000 Status - 01/20/2016
aldaran is offline   Reply With Quote
Old 11-29-2017, 12:03 PM   #5
SSDanny
Everything was fixed with the vehicle, except this problem. Apparently the shop never had it happen when they had it, but every time I lock the car it does the "unlock, lock, and unlock" thing on its own.
Old 11-29-2017, 12:04 PM   #6
SSDanny
I have that set-up as well, but after the car locks, a couple seconds later it automatically unlocks, locks, and unlocks the lock on the door always leaving my door unlock.
I have to wait outside my car until it does this so I can lock it again, and then it won't do it.
Old 11-29-2017, 12:35 PM   #7
Cameron27
Drives: 2015 2SS
Cameron27 is offline   Reply With Quote
Old 11-29-2017, 12:43 PM   #8
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Most of the time when you have a “stuttering” on the locking mechanism/solenoids, it’s because the current is intermittent. Start checking all your wiring and connectors with a continuity tester. You may have an intermittent connection, Common when reassembling wiring systems.
Old 11-29-2017, 04:44 PM   #9
SSDanny
Originally Posted by Cameron27 View Post
I would bet this is one of two possibilities. Both are assumptions, I don’t know how the software or sensors are actually set up:
1. The car door has a malfunctioning sensor. First lock occurs. Door sensor detects the door should remain unlocked. Unlock occurs. Car software determines door should actually end in locked position. Second lock occurs. Malfunctioning sensor doesn’t cause a second unlock because it only activated once in this cycle, based on software.
2. The car door has a sensor that detects something is not to proper spec. The lock signal is sent to the car. Since the door sensor thinks something isn’t as it should be, the car initiated an unlock and relock sequence to ensure the safety feature (unlocking) is accessible.
I feel like your second answer might be the case, since this did occur right after the accident and the body shop didn't fix it since.
Old 11-12-2024, 09:41 AM   #10
manuelram16
Drives: 2020 Camaro SS
Sorry to bring up an old post but did anybody found a solution for this ? got the same problem....car was in accident and repaired, codes cleared and wiring checked
manuelram16 is offline   Reply With Quote
Old 11-12-2024, 08:05 PM   #11
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
My car occasionally unlocks after I locked it. I suspect it is when I wave the FOB by the door edge when exiting. I have been more careful and it seems to help.
My car is totally stock and has had no repairs so guess this is an anomaly it came with.
cgdelena is offline   Reply With Quote
Old 11-16-2024, 10:42 AM   #12
manuelram16
Could be cgdelena, do you find your car unlocked sometimes and when you open the door the alarm activates ?
Old 11-16-2024, 12:24 PM   #13
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
No alarm, just unlocked. Sometimes I hear it unlock when I am standing there after locking it.
Old 07-26-2025, 06:59 PM   #14
manuelram16
Found a GM TSB that may explain the problem:
https://www.tsbsearch.com/Chevrolet/PIC6373
