Old 11-28-2017, 07:58 AM   #1
tchowe
Drives: 2017 V6 Camaro RS
Black low gloss rim paint fading
I’ve had the car for about 11 months now and only hand wash the body and rims with Meguiars car soap and a microfiber mit, and occasionally use Sonax wheel cleaner plus. Lately I’ve been noticing issues with the paint on my rims. Seems 2 are affected right now, both on the driver’s side. Does this look like a paint defect from the factory, or possibly something acidic in the road that ate away at the paint?
tchowe is offline   Reply With Quote
Old 11-28-2017, 08:25 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
How often are you using with sonax? Shouldn’t be more than once or twice a year
Gm paint is bad, stop all this foolishness and find yourself a good powdercoater.
Old 11-28-2017, 08:33 AM   #3
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
Mine are doing the same, and I've seen a couple threads come around about it. These wheels probably should have been powdercoated from the factory. It's what I'll probably do as a solution to my problem, as I have driven myself far beyond warranty replacement (48,800 miles).
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 11-28-2017, 08:34 AM   #4
tchowe
Not often, the last time I did it was about 6 months ago, and before that probably 2 or 3 times.
Old 11-28-2017, 08:35 AM   #5
tchowe
Luckily I'm still under warranty, so if it's not something caused by me or road conditions I'm definitely going to try for a warranty fix.
Old 11-28-2017, 09:15 AM   #6
Blazin383
Blazin383's Avatar
Drives: 2016 SS
That’s a lot worse than mine, but I do have one wheel that’s getting these mysterious white spots that seem to be spreading. The car has never been through a car wash or had anything used on the wheels other than Meguires car was soap! I showed my service guy and he said they want to try and buff it out and if it doesn’t come off, which I’m sure it won’t, they’ll replace the wheel. BTW, these 20” low gloss wheels are $875 ea at the dealership!
Blazin383 is offline   Reply With Quote
Old 11-28-2017, 09:55 AM   #7
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
i would hope warrantee would cover this. that is exceptionally bad!
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 11-28-2017, 10:12 AM   #8
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
One on my rims is doing that but not that bad. The dealer says I can bring it in to be repainted. But it will take a few days. Just havn't had a chance and not ready to give up car for a rental. I'm waiting for when they predict snow then I will drop it off because I won't be driving in the snow anyway.
Marty McFlew is offline   Reply With Quote
Old 11-28-2017, 10:43 AM   #9
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
If they fix it, under warranty, it will just happen again. It’s because they use cheap paint and a cheap paint schedule.
Once again, spend the money, and get the powedercoat.....
Old 11-28-2017, 10:53 AM   #10
Spanky1
Drives: 2017 2SS Summit White Camaro M6
On average how much would powdercoating run?
Spanky1 is offline   Reply With Quote
Old 11-28-2017, 10:57 AM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
It runs the gamut ....depending on the honesty of the place. Figure $100 a wheel.
Old 11-28-2017, 12:01 PM   #12
JR91
Drives: Camaro 1SS
Mine looks the same. May go the powdercoating route after this winter season.
JR91 is offline   Reply With Quote
Old 11-28-2017, 04:40 PM   #13
gringo
gringo's Avatar
Drives: Camaro V6
Powdercoat can also fade as well. So, be aware of that too.
gringo is offline   Reply With Quote
Old 11-28-2017, 05:56 PM   #14
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Mine are in perfect shape after almost 2 years. I use nothing but car soap and I keep them waxed. I think powder coat is the way to go though.
dpevans is offline   Reply With Quote
