Old 11-25-2017, 03:50 PM   #1
Cvenom
Drives: 2017 Camaro 2.0t
Question 14.033 @ 99 mph bolt ons tune ???
Hey guys I got a 2017 Camaro 2.0t automatic I put on a injen intake, zz performance hi flow cat, SLP loudmouth pipes and zz performance tune. I got two passes first one was 14.1 @97 mph 2.1 60ft I had on all the aids and used the launch control feature.
2nd pass I turned off the TC and stability Trac I spun at the line and got a 14.033 @ 99 mph 60ft was 2.3 which is bad but still that trap speed looks a little slow doesn't it?
I had a Saturn ion redline with stage 2, bolt ons and a smaller pulley ran a 13.8 @ 103
What is the best way to launch the 2.0?
My hp tuner logs look great running 11.5 air fuel WOT, and no knock, boost 22-24psi
Am I expecting to much from the lnf or is my driver mod broken 😂
I'll post slips and videos in a few
Cvenom is offline   Reply With Quote
Old 11-25-2017, 03:58 PM   #2
Cvenom
https://youtu.be/Zp_uvUMDo2Y
Old 12-09-2017, 12:49 PM   #3
jw0287
Drives: 2016 1SS NPP Black on Black
I watched your vid and read your post. Idk much about these cars. I was in one for a few days when the dealer had some warranty work to do with my car. It wasn’t slow but it wasn’t fast. All stock of course.
Fun.
My wife’s 350 Lexus felt faster. But it’s heavier.
Anyway, what tire pressure are you running?
Did you warm up the tires so you don’t spin?
For my SS, I got it to hook a few passes last night.
I do burnouts till I see smoke at the front of the car. Like a good 10 second burnout.
Keep tires clear of water if possible. If not def need a good burnout.
Tires I run between 19-21 depends on what the guage says. I’ll stop at 20 but sometimes it’s 21 an I leave it. Sometimes it goes to 19, and I leave it.
Hold the brake wait for 3rd amber light and stomp on the gas. TC off. Stabil track off for me.
Could help you out. I don’t know. Good luck.
Looks like your chasing 13s for now and hopefully 12s soon.
If you keep spinning - upgrade your tire.
jw0287 is offline   Reply With Quote
Old 12-14-2017, 05:22 AM   #4
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Launch at 2500 rpms, shift at 6k
6th_gen_gino is offline   Reply With Quote
