Old 11-25-2017, 12:00 AM   #1
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
295/30R19 tire too wide for 19 x 10" wheel ...?
I am looking to fit Michelin Pilot Sport 4S tires for Spring 2018... they don't make a 285/30R19 and I don't really want to go down to 275/30R19 and lose some of the front end bite.
I worried about possible handling issues since 285 is considered the upper range for a 10" wide wheel...
I might consider getting an all new setup with adjustments stable camber plates from Morena, and Z06 front spats and trimming down the MRC shock to go whole hog with :
305/30r19 front on a 19x11 ( or 10.5) and a 325/30r19 rears with a 19x12 wheel
Thoughts ? Suggestions?
EDIT: realized the title had the original size... tital now says 295, not 285
aa406079 is offline   Reply With Quote
Old 11-25-2017, 01:17 AM   #2
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
285 is a perfect for for 10 inch width. 9.5 is minimum and 10.5 is max per manufacturer. I dont know why you think its narrow.
9.5 = 275
10 = 285
10.5 = 295
11 = 305
WhiteNight is offline   Reply With Quote
Old 11-25-2017, 06:39 PM   #3
aa406079
9.5 = 275
10 = 285
10.5 = 295
11 = 305
sorry, my subject title should have said 295/30r19 , not 285/30R19 on a 10" wide wheel
Old 11-25-2017, 06:45 PM   #4
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
It fits fine. I’m running 295/30/20 on the OEM 1LE wheels. No clearance issues at all.
Chris V is offline   Reply With Quote
Old 11-25-2017, 06:52 PM   #5
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Also different manufacturers measure their tires differently. Dont chase a size. Look at the actual dimensions. For instance, a Michelin Super Sport runs very wide while Nitto tires are more narrow. It also has to do with the shoulder blocks. Some are more squared while others rounded.
Old 11-26-2017, 01:38 AM   #6
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
It should be just fine
By the way, I was using 305/30/19 and 325/30/19 on 10.5" and 11" wheels with no ill effects
glamcem is offline   Reply With Quote
Old 11-27-2017, 09:39 PM   #7
ICTsccaCamaro
Drives: 2018 ZL1 1LE
I run a 305/30R19 on the front of my 19x10 autocross wheels, as does every other FS 1LE 5th gen Camaro with no issue.
ICTsccaCamaro is offline   Reply With Quote
Old 11-28-2017, 12:24 PM   #8
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i wanted 285 in front on my car on 20x10 wheel but ordered 275 and they fit wide and they run wide btw lol good luck
