Old 11-18-2017, 12:32 PM   #1
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Rear Diff Service
I’m sitting in a dealership and I was initially quoted $250 for a rear diff service. The Service Adviser then comes up to me and says that it’s a 4 hour procedure that would be $680 but, he could knock off $40. No thanks! WTF!? I told him that I didn’t want the elsd serviced just the diff. No joy.
Old 11-18-2017, 12:36 PM   #2
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
lol, just do it yourself. I was quoted north of $300 for mine, I did it in my driveway, took 15 minutes & cost me $20. And doesnt elsd stand for electronic limited slip diff? That is what you're trying to service.
soloknight6 is offline   Reply With Quote
Old 11-18-2017, 12:50 PM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Originally Posted by ZL1 1LE View Post
I’m sitting in a dealership and I was initially quoted $250 for a rear diff service. The Service Adviser then comes up to me and says that it’s a 4 hour procedure that will take 4 hours and would be $680 but, he could knock off $40. No thanks! WTF!? I told him that I didn’t want the elsd serviced just the diff. No joy.
I think the dealer is quoting you the price to change the fluid in the ESLD. From what I understand that’s a pretty involved procedure. You just want the rear axle fluid changed. That should run you about $150 from the dealer.
Old 11-18-2017, 12:51 PM   #4
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
There’s a separate reservoir for the elsd that doesn’t require nearly the replacement intervals that the diff does.
Old 11-18-2017, 12:52 PM   #5
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
The dealer entered the wrong code if he said it’s 4 hours. It’s faster than an oil change,
As there is no filter to worry about. It’s simply remove drain and fill plug, let drain for 10ish mins, replace drain plug. Fill with 1.6qt, replace fill plug......done.
He must have included other additional diff related services.
ninetres is offline   Reply With Quote
Old 11-18-2017, 12:52 PM   #6
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
I know but, I can’t convince them that I know more than they do.
Old 11-18-2017, 01:50 PM   #7
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
run
speedraider is offline   Reply With Quote
Old 11-18-2017, 04:36 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
go to a new dealer...the eLSD only requires a typical drain & refill
