Old 11-17-2017, 04:41 PM   #1
flaps100
flaps100's Avatar
Drives: 2017 Camaro 2.0 RS
Radio Rattle?
Well, my 1st issue with my 2017, minor but really maddening.
Anything other than perfect surface roads, my 8" screen rattles, I can put light pressure on it and it stops.
I can play with it and its not loose but its not tight either, anyone else have this and if so how did you fix it.
I thought I could put some felt behind it, but there really is no where to hide anything to quiet it down, plus I was worried about heat?
Thoughts , opinions?
Thanks, Chris
flaps100 is offline   Reply With Quote
Old 11-17-2017, 07:07 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
Can you remove the trim and make sure it’s tight? I’m not sure how it mounts. My concern would be messing something up. If you can get it to easily make the noise, a trip to see the dealer may be the best move.
Old 11-18-2017, 12:27 PM   #3
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Mine does the same thing. I'm thinking of asking the dealership if they can fix it.
classicrockr is offline   Reply With Quote
Old 11-18-2017, 10:05 PM   #4
KS1LE
KS1LE's Avatar
Drives: 17 SS 1LE, 02 GTP
Mine just started to rattle also.
2017 Mosaic Black Metallic 1LE
KS1LE is offline   Reply With Quote
Old 11-19-2017, 08:01 PM   #5
rotohead
Drives: 2017 Camaro RS
It's a easy fix with 1/8th inch foam tape.
rotohead is offline   Reply With Quote
Old 11-20-2017, 01:05 AM   #6
CamaroBody
Drives: Hyper Blue 2SS
mmm that sounds good. you should try that
2SS, Hyper Blue, 8-Speed Automatic, NPP Exhaust, Magnetic Ride Control, Sunroof, Navigation, 5-Spoke Low-Gloss Black Wheels, Black Bowtie Emblems, Cargo Mat/Net
Mods:
XPEL - Hood, Bumper, Headlights, & Side Mirrors
JWM - Side Markers
ZL1 Addons - Deluxe Rock Guards & Red Lift Pads
GM - Dark Tail Lamps
MRR - Gloss Black M017s
CamaroBody is offline   Reply With Quote
Old 11-20-2017, 08:04 AM   #7
17txcamaross
Drives: 2017 Camaro 2SS
Can someone post pictures of how they are able to fix this. I had shrugged it off, but at this point I am in the same boat as the OP. This rattle is driving me insane. Need to fix this rattle and the caps on the bottom of my doors that rattle from the door speakers.
If the foam tape works for the radio and someone can post where it needs to be installed I will be knocking them both out before taking my Camaro on it's first road trip (250 miles one way).
17txcamaross is offline   Reply With Quote
Old 11-20-2017, 11:02 PM   #8
KS1LE
KS1LE's Avatar
Fixed mine today with some foam tape.
I removed the trim piece from the bottom and removed the two bolts holding it in. Put the tape on top between the upper hooks.
Old 11-21-2017, 12:06 AM   #9
flaps100
flaps100's Avatar
Good info, have you driven it some to see if the rattle is gone? Thanks,
Old 11-21-2017, 07:13 PM   #10
KS1LE
KS1LE's Avatar
Yes, no more rattle.
rotohead was correct, just a little tape and it's good.
Old 11-23-2017, 10:35 AM   #11
classicrockr
My dealership just put some thin foam tape under the head unit borders. Quite as can be now.
Old 11-23-2017, 12:27 PM   #12
Smashn808
Smashn808's Avatar
Drives: SS
Dealership fixed mine also.
2017 HBM 1SS 1LE w/PDR
Past:
2009 Cadillac CTS-V, 6-speed manual
2008 Corvette Jet Steam Blue, manual
2005 Cadillac CTS-V, Stealth Gray
2003 Corvette Z06, Black
Smashn808 is offline   Reply With Quote
Old 11-23-2017, 12:59 PM   #13
fastball
Drives: 2017 Camaro 2SS 6MT
Smash it with a hammer. That should stop it no?
fastball is offline   Reply With Quote
Old 12-04-2017, 08:21 PM   #14
Allez
Allez's Avatar
So where is everyone putting the tape? Is it as described by KS1Le where the bottom trim needs to be removed?
Allez is offline   Reply With Quote
