Old 11-14-2017, 04:58 PM   #1
bryguycbr
bryguycbr's Avatar
Drives: 2016 2SS Nightfall Gray
Send a message via Yahoo to bryguycbr
OBD II specifications
I'm looking for a document, or web address, that shows what the value of each parameter should be while a Bosch OBD II scanner is connected. For example when the Bosch OBD is connected I can read, Cranking Voltage : 9.2, is there a document or web site that describes what this Cranking Voltage should be?
2016 2SS, Nightfall Gray Metallic, Jet Black Leather, A8, MRC, Clear-Bra, ROTO-FAB CAI sound tube removed, Stainless Works Catback with AFM valves, ORACLE ghosted sidemarker set
bryguycbr is offline   Reply With Quote
Old 11-14-2017, 07:45 PM   #2
glenB
Drives: Chevrolet Camaro SS
You're gonna need the GM Service Manual for most of the specs. Most of these vary by manufacture
glenB is offline   Reply With Quote
Old 11-14-2017, 07:53 PM   #3
bryguycbr
bryguycbr's Avatar
I've been talking with some auto mechs, I found what I'm looking for, I might also look into GM documents.
Old 11-14-2017, 08:53 PM   #4
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Is there any odb high level available
Who permits some reprog?
Engine, trans..,
Or is it just passiv, scan and tells only parameters?
Are you happy with your Bosh odbII?
Biscuit.fr is offline   Reply With Quote
Old 11-14-2017, 11:24 PM   #5
bryguycbr
bryguycbr's Avatar
Engine, trans..,
I have the Bosch Enhanced OBD I & II Scan, I can view all parameters and clear check engine light codes.
I'm pleased with the operation of the Bosch, when I finish downloading the interface to my laptop, then I'll be able to save the ECM numbers.
Old 11-15-2017, 03:47 PM   #6
bryguycbr
bryguycbr's Avatar
I downloaded ECM numbers using Bosch Enhanced OBD 1 & 2 Scan, this is what I have, driving down my street at 31 MPH.
ABS FRP(PSI) 1195.11
ABS LOAD(%) 32.2
ABS TPS B(%) 22.4
ABSLT TPS(%) 22.4
ACC POS D(%) 27.1
ACC POS E(%) 13.3
BARO PRS("HG) 28.9
CALC LOAD(%) 19.6
CAT TEMP11(°F) 1274
CAT TEMP21(°F) 1195
CLR DIST(mi) 81
CLR TRPS 6
CMD EQ RAT 0.999
COOLANT(°F) 190
ENG RUN(m:s) 16:29
ENG SPEED(RPM) 1364
EVAP PURGE(%) 49.0
EVAP VP(H2O) -1.801
FRP_A(PSI) 1191
FRP_A_CMD(PSI) 1182
FRP_B(PSI) 1178
FUEL LEVEL(%) 18.4
FUEL PRES(PSI) 57
FUEL PRES(PSI) 54
FUEL SYS 1 CLSD
FUEL SYS 2 CLSD
FUEL TYPE GAS
IAT(°F) 88
IAT 11(°F) 88
IAT 12(°F) 115
IGN ADV(°) 17.0
LT FTRM1(%) -2.3
LT FTRM2(%) -0.8
MAF(LB/M) 0.99
MAP("HG) 14.2
MIL DIST(mi) 0
MIL STATUS Off
MIL STATUS Off
MIL STATUS Off
O2S11(V) 0.080
O2S12(V) 0.690
O2S21(V) 0.780
O2S22(V) 0.080
OBD2 STAT JA/CA
OUT TEMP(°F) 70
REL TPS(%) 3.5
ST FTRM11(%) 3.1
ST FTRM21(%) 6.3
ST FTRM1(%) 7.0
ST FTRM2(%) 6.3
THROT CMD(%) 4.7
VEH SPEED(MPH) 31
VPWR(V) 11.828
VPWR(V) 12.521
VPWR(V) 12.150
