Old 11-11-2017, 03:39 PM   #1
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Ticking noise after header install - HELP!
Just installed long tube headers and noticed a ticking sound coming from the passenger side header area. I get the feeling its an exhaust leak from a bad gasket or something but if anyone can tell me what it is, that would be really helpful.
I don't quite want to take it in to the dealer yet if it's something basic we can fix.
Here's a sound clip.
marknagy13 is offline   Reply With Quote
Old 11-11-2017, 03:46 PM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Sounds like an exhaust leak. Did you use new OEM GM exhaust manifold gaskets? Did you torque the bolts in the proper order to the proper spec?
Old 11-11-2017, 03:55 PM   #3
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I did use new gaskets, however I did not torque them to correct spec. The kooks instructions had no info on that so we just made them tight haha
Old 11-11-2017, 04:18 PM   #4
Capt Insaino
Drives: Fifty Anniversary Camaro
When installing headers I usually tighten the header bolts down from the inside out. I have never had a leak doing it that way.
Capt Insaino is offline   Reply With Quote
Old 11-11-2017, 04:43 PM   #5
JeromeS13
Drives: 2017 1SS/1LE
The Kooks instructions say to install per factory specs...
Old 11-11-2017, 05:49 PM   #6
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I have no idea what those are and we didn't have a torque wrench
Old 11-11-2017, 06:06 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I have never used factory torque specs because they have always been for manifolds and not long tube headers. I have always tightened them down starting from the middle, then the ends, and work back to the middle alternating. Never had a Issue.
Old 11-11-2017, 06:08 PM   #8
brettman
Drives: 2016 Camaro SS
You didn't use the included Kooks gaskets did you???
That was part of my problem, they are stamped incorrectly and leaked
brettman is offline   Reply With Quote
Old 11-11-2017, 06:46 PM   #9
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Nope I used OEM. Is it possible they loosened up? I've heard that after a few heat cycles that can happen
Old 11-11-2017, 07:21 PM   #10
EFI Tuning
EFI Tuning's Avatar
Go back over them. Likely they loosened up.
EFI Tuning is offline   Reply With Quote
Old 11-11-2017, 07:35 PM   #11
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
And this is why you should do it correctly the first time.
Old 11-11-2017, 08:47 PM   #12
JeromeS13
Mine came with Cometic gaskets and Grade 8 locking fasteners. I had no issues.
Old 11-12-2017, 08:46 AM   #13
AchiliesSS
AchiliesSS's Avatar
Drives: 2017 Black on Black 1SS
Is it fixed yet? Any update, I wonder if there is going to be a tick considering the metals is thinner and a result in more exhaust noise, I know these have been a reason for why tuners had to turn down the sensitivity of the knock sensors. Please keep us updated and I hope you find the fix brother I'm sire it's nothing serious
AchiliesSS is offline   Reply With Quote
Old 11-12-2017, 03:45 PM   #14
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Not yet. I dont have the right tools to tighten the bolts at home. I'll probably take it in this week and see what they say.
