Old 11-07-2017, 01:27 PM   #1
CarFlow1
Drives: 2017 ZL1 A10 (Summit White)
Suspension
Does the ZL1 have a switch for shutting off the suspension? I would imagine there is for the purpose of lifting up the vehicle.
CarFlow1 is offline   Reply With Quote
Old 11-07-2017, 01:32 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
No. But you wouldn't need to?
I'm confused what the purpose would be. It turns on and off with the rest of the vehicle systems...
Old 11-07-2017, 01:38 PM   #3
CarFlow1
For background: I'm trying to figure out some root causes of a bad suspension sensor. I'm getting some work done where I had a new set of wheels installed and some rear suspension work. I was told that GM advises to calibrate the suspension whenever new wheels are installed.
The shop got back to me informing one of my suspension sensors went bad. I'm just curious how, either lifting it up etc.
Old 11-07-2017, 01:43 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
The shop got back to me informing one of my suspension sensors went bad. I'm just curious how that is all
What suspension work? Sounds like maybe they forgot to remove the arm to the ride height sensor and broke it.
Eric SS is offline   Reply With Quote
Old 11-07-2017, 01:58 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
By who? They're wrong. That rationale makes no sense whatsoever based on how the MRC's operate.
However, ride height sensors are frequently broken by incompetent shops that forget to disconnect them prior to removing the springs & dampers. If you overextend them their tie-rod easily snaps.
Old 11-07-2017, 02:02 PM   #6
CarFlow1
Just the level of insight I was looking for, they repaired the Right and Left Backing Plates
Old 11-07-2017, 02:05 PM   #7
CarFlow1
Wow this is useful information, it does sound a bit strange. They claimed to have had a conference call with someone at a GM dealer stating this - but it doesn't factual to me.
Old 11-07-2017, 02:06 PM   #8
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Backing plates, like for the rotors? Why would you need those replaced?
Even if there's a way to "reset" the sensors, no aftermarket shop has that capability. The MRC computer is simply looking for an ADC value and calculates the damping force PWM output to the damper based on all the vehicle sensor data plus the ride height sensor position delta vs. time. When your shop replaces the sensor, it's critical they make the tie rod the same length as it was originally.
Old 11-07-2017, 02:17 PM   #9
Mr. Wyndham
If you put a wheel and tire combo on that was different from the factory - all you may need to do there is recalibrate the computer for your speedometer...again, nothing to do with the suspension.
Old 11-07-2017, 02:18 PM   #10
CarFlow1
Good point, I'm leaning more towards having the car taken out of there. Installing a sensor sounds much more complex.
Old 11-07-2017, 02:21 PM   #11
CarFlow1
This is very helpful as a different set of wheels and tires were installed as well. Why would the computer for the speedometer need to be calibrated?
Definitely, taking the vehicle elsewhere now.
Old 11-07-2017, 02:25 PM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Definitely, taking the vehicle elsewhere to get diagnosed.
If your new tire rolling radius differs significantly from OEM then the speedometer needs to be calibrated. Otherwise it'll read either high or low, depending on which way the tire size went.
This is why over in the wheel & tire sub-forum we try to ensure the new tire's we choose have a rational rolling radius.
Old 11-07-2017, 02:27 PM   #13
Tim202
If you're doing different wheel size and/or tire aspect ratio, the speed will be incorrect. ***Doh, Ryephile beat me to it***
Tim202 is offline   Reply With Quote
Old 11-07-2017, 02:29 PM   #14
CarFlow1
That explains why the back-end felt more ''bouncy'' at higher speeds.
