Old 11-06-2017, 05:56 PM   #1
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
What part is this?
Anyone know what the part number is for this? It is like a catch can for the LT1 if I'm not mistaken that has 3 PCV connections. I had a broken connection on it and when trying to pull it off I ripped the entire top lid off.
So looks like replacing the piece and finally replacing the connector.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 11-06-2017, 07:01 PM   #2
brettman
Drives: 2016 Camaro SS
12672471 air intake separator.
Is that your engine??? Apart??
Tape those ports closed!!
If so, whats up now??
If it's a quick disconnect, you should have some from your whipple kit.
If a broken stem, glue and sleeve it
OOPS, whole lid?? Fix it...lol
brettman is offline   Reply With Quote
Old 11-06-2017, 07:06 PM   #3
Joe's_cool_1le
Is that your engine??? Apart??,
LOL. That's when the SC was getting installed. I thought it would be an easier picture to see. I ripped the damn top of it off when trying to remove a bad connector that the had a vacuum leak coming from it which was dropping my boost.
Here's what it looks like under the connections haha.
Old 11-06-2017, 07:08 PM   #4
Joe's_cool_1le
Hey Brett. That part number says its no longer available for purchasing.
LOL
Old 11-06-2017, 07:09 PM   #5
Joe's_cool_1le
Flex seal to the rescue
Old 11-06-2017, 07:12 PM   #6
brettman
https://www.ebay.com/sch/i.html?_fro...71&_sacat=6000
OR, just glue it
Old 11-06-2017, 07:15 PM   #7
Joe's_cool_1le
Yeah.. I'll definitely put a patch for now because it looks like the front needs to come off so I can replace it when I get that cam put in.
Old 11-06-2017, 07:19 PM   #8
brettman
what me to send you the GOOD stuff??
Old 11-06-2017, 07:23 PM   #9
Joe's_cool_1le
I'm going to goggle that stuff there! I wonder if I can buy it locally,
Old 11-06-2017, 07:28 PM   #10
brettman
It's a two part epoxy, you need gun also. I have tubes of it.
If done right, it is done like factory. Shipping is cheaper then
replacement....lol
Old 11-06-2017, 07:29 PM   #11
Joe's_cool_1le
replacement....lol
LOL. True
Old 11-06-2017, 07:37 PM   #12
brettman
PM your address again, I'll send it out tomorrow.
Discard the tip, cap tube and send it back
Old 11-06-2017, 07:47 PM   #13
Joe's_cool_1le
Thanks Brett. After reading up on it I bought it off of Amazon. I think it's a must have for the tool chest and the father-in-law said he has the gun for it.
Thanks again man. You saved the day. This almost got me started on a cam swap earlier then I was expecting.
Old 11-06-2017, 07:55 PM   #14
brettman
Great, it's good stuff (wear gloves...lol) Thats a $90.00 save on the fix, and better then OEM. You don't really need the tip (sometimes I just mix on cardboard and puddy knife in) A lot of waste in the nozzle. But good to lay a nice bead. Don't forget dry time!!!
