Old 11-01-2017, 07:39 PM   #1
dizo702
dizo702's Avatar
Drives: 2016 I4 turbo Camaro M6
P0304 MISFIRE ON CYLINDER 4 -I4 Turbo LTG (updated with pics)
hey guys I need some help here . I am getting code P0304 code which indicates that Cylinder 4 had too many misfires within a predetermined period of time. which also caused P0420 which means the Catalyst system had low efficiency in bank 1. The guys at autozone think its an issue with my catalytic converter or maybe an exhaust leak? Any help is appreciated.
MODS:
65MM throttle body
Hi-Flow catalytic converter
Full Borla S-Type exhaust
Stage 2 performance tune by RPM-Motorsports
Everything was installed around July and has been running fine since then.
dizo702 is offline   Reply With Quote
Old 11-01-2017, 07:54 PM   #2
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Good info in here:
https://www.yourmechanic.com/article...pencer-clayton
http://www.troublecodes.net/pcodes/p0304/
Old 11-01-2017, 08:22 PM   #3
dizo702
dizo702's Avatar
Originally Posted by MiamiBlueCamaro View Post
Thank you! this definitely helps it makes me feel like its the spark plugs which is an easy check. I've never touched the spark plugs on this car is there any guide online to changing them?
Old 11-02-2017, 09:03 AM   #4
dizo702
dizo702's Avatar
Unfortunately, I could not find a clear guide for the LTG so I just started turning wrenches and, to be honest it should have been expected lmao, I obviously ripped the coil pack completely off the rubber seal around the spark plug and now I can't get that rubber seal out! I'll take a picture later today and hopefully somebody can give me some advice because I am getting the feeling that I really messed up here.
Old 11-02-2017, 04:38 PM   #5
dizo702
dizo702's Avatar
The first picture is from the #1 coil pack. I removed this one to help show anybody what it was supposed to look like. In the second picture is from the #4 coil pack and you can see where i ripped it completely apart. In the third picture this is the rubber piece that will not come off, both me and my father tried pulling with all the strength we had and it will not budge. Don't get me wrong it is in a very difficult spot and we could get no leverage at all but there is no way it shouldn't have just come right out
Old 11-02-2017, 04:41 PM   #6
dizo702
dizo702's Avatar
Old 11-02-2017, 08:31 PM   #7
dizo702
dizo702's Avatar
Ok I was able to get the coil off with some vice grips and the spark plug is burnt up pretty bad. I'm very much relieved its a quick fix but does anybody know what might have caused it?
Old 11-03-2017, 09:53 AM   #8
suzook
Drives: camaro
Probably your tune. Check your other plugs.
Hyperblue/JetBlack
Old 11-03-2017, 10:23 AM   #9
SoCalThug
Drives: 2012 Summit White 1Ls
Your tune
http://www.camaro6.com/forums/showthread.php?t=512275
SoCalThug is offline   Reply With Quote
Old 11-03-2017, 06:44 PM   #10
TJay74
I am going to lean towards the tune being too rich as well. Make sure you put some dielectric grease on the plug porcelain so the boot doesnt get stuck again.
Old 11-06-2017, 07:23 PM   #11
dizo702
dizo702's Avatar
Originally Posted by SoCalThug View Post
Looks like you guys might be right. I changed all 4 spark plugs and the coil with OEM parts from rockauto and still no change. I sent an email to RPM hopefully they can help me out here.
