Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > CANADA
Old 11-01-2017, 02:02 PM   #1
tej
Drives: 2018 2ss Borla ATAK Cat Back
Blizzak WS80 winter tires advice
Hello Guys,
I called bunch of tire places to find which one is good for winter and mostly recommended me Blizzak WS80, I own 17 v6 with rs package.
Blizzak WS80 18 Inch is going for $1450+ with steel wheels and 17 inchs are around 1100 with steel wheels. If i down size to 17 will there be any issue with handling or anything like that ? or should i go for 18 without steel wheels if they can fit on my stock 20 inch wheels Please advice.
tej is offline   Reply With Quote
Old 11-01-2017, 08:38 PM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Staying stock would require paying to swap them out every season.
Steelies allow you to switch easily...and sell them if you have too.
Switching to a 17 will give you the same height but more sidewall. That would give a nicer ride.
I would go 17" steelies save some money and enjoy the smoother ride
Old 11-02-2017, 11:42 AM   #3
snake3276120
snake3276120's Avatar
Drives: 2018 2SS 1LE
Downsizing 1 inch is better for winter. Do not swap the stock tires for winter tire on the same rims. Check with wheelsco.ca they might have a better price. Also, I suggest going with alloy rims... steel rim might get rusted over time.
snake3276120 is offline   Reply With Quote
Old 11-12-2017, 09:43 PM   #4
Tigger-SS
Tigger-SS's Avatar
Drives: 2017 Camaro 2SS M6
Iam curious why would you risk or want to drive the camaro in winter,mine is parked and covered in my garage till spring.ive seen a couple around here trying to get around and it's funny and also the car isn't meant in my thoughts to be driven in snow that's why you buy a winter beater.Just my thought
Tigger-SS is offline   Reply With Quote
Old 11-13-2017, 04:22 PM   #5
TopHatPlus
Drives: 16 2SS NPP MRC
i bought my tires for my SS at dream trie on harvester in oakville. Tires were $700 mounted on s set of 18" steel rims i purchased form them for $300. I purchased use camaro LS rims from 2010 which are quite common on kijiji and are a great fit only 16 ss.
Dropping rim size isn't the important thing it really only saves you money. Narrower tires are the key. You want to cut into the snow.
TopHatPlus is offline   Reply With Quote
Old 11-13-2017, 08:20 PM   #6
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
Because its just a car - with enough nannies and systerms built in that make winter driving a breeze. Anyone you saw suffering wasn't using 4 snow tires or had never driven in winter with e RWD car. I was raised that way.. its a piece of cake.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 11-13-2017, 08:29 PM   #7
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
I’ve driven a Camaro year round for coming up on 5 years with no issues. I swap my all season tires for dedicated winter wheels and really have no issues getting around. The Camaro is plenty safe with proper tires. The notion that a rear wheel driven vehicle can’t be driven in the winter is silly. I hear it every year, in person and on these boards.
SPARTAN sui is offline   Reply With Quote
Old 11-14-2017, 10:19 AM   #8
tej
Thank you, everyone, for your input, bought Blizaakws80 with 17 steelies from tireworldbrampton $1025 all in.
Old 11-14-2017, 10:58 AM   #9
BradfordCamaro
SABIO
There were only 2 days last winter I had issues with getting around.
I have BFG comp2 A/S in the stock 20" size.
Last week's snow caused zero issues for me.
Drive with a brain and its no problem
Enjoy the 17s. You will have no issues this year.
Old 11-16-2017, 02:21 PM   #10
Tigger-SS
Tigger-SS's Avatar
Oh I know all about winter driving growing up in Alberta plus driving highway tractor for years.All I was saying was it seems a shame to drive a car like we own in the snow and salt and chemicals,plus the chance of someone sliding into you at a light or stop sign.I bought mine to enjoy in the summer for the mountain road trips and just fun times cruising
Old 11-16-2017, 08:20 PM   #11
Homer2
Homer2's Avatar
They will make more.
Old 11-17-2017, 07:51 PM   #12
SPARTAN sui
PC Technician
Yeah I hear you, if I could afford a third vehicle that would be great. Luckily they use mostly sand here versus salt. Make no mistake, the Camaro is still a lot of fun in the winter months.
Also thankfully I can now walk to work, so less driving to and from work now.
Old 11-18-2017, 06:20 PM   #13
Gunsmokez
Gunsmokez's Avatar
Drives: 1LE
I live in the city, even with winter tires on it is useless. Others who are driving on all season will plow into my car. Also, main roads are fine. But, our side streets when the snow starts coming down. The camaro is basically a snow plow with the low clearance. Would not even be able to get it into my garage.
So, best way. Transit Or get a winter beater. That sucks, since our insurance is quite expensive and maintenance on a second vehicle is waste.
Gunsmokez is offline   Reply With Quote
