Old 10-31-2017, 07:40 AM   #1
DSX Tuning
Drives: 2019 Corvette ZR1
A little info about DSX fittings
The small details that 99% of people never notice are the things I actually get some sense of satisfaction out of.
I outsource the CNC machining of my custom fittings, but I handle the design and assembly 100% myself. I've opted to use fluorosilicone o-rings inside instead of Viton due to the far better chemical resistance (fluorosilicone is rated excellent for everything that might even touch the o-ring). I took the time to research proper gland design instead of just picking some dimensions that sort of work (which I found is what most places do unfortunately) so that the double o-rings seal properly without excessive installation force.
Installing the o-rings is a pain in the ass, but I used my 3D printer to make an installation tool which significantly sped up the installation. I made a point to use an exceptional grease with PTFE to minimize the possibility of tearing the o-rings as well as give a better tactile feel upon installation. I wound up making a go/no go gauge which serves the purpose of fully seating the o-rings but also ensures that the fittings will fit a worst case scenario connection. It is true 0.375" diameter as opposed to most rails and sensors that come in around 0.373"-0.374".
There's also a very small lip inside meant to align and seat the stainless steel retainer clip that goes in to keep it positioned properly at all times and make sure it doesn't wind up crooked with a possibility to come loose.
These little things are what I enjoy scrutinizing. I just hope it shows through in the end!
DSX Tuning is offline   Reply With Quote
Old 12-25-2017, 12:51 PM   #2
parbreak
Drives: 2017 50th Camaro SS
Just received your flex fuel kit for Christmas from my son. Fittings and build quality look excellent. Can't wait to install.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 12-25-2017, 06:22 PM   #3
DSX Tuning
Thank you for your feed back! Enjoy. Sounds like a good son.
Old 12-30-2017, 07:47 PM   #4
NickyRacerBoy
Drives: 1LE
I would never doubt the final product that Dave would bring to mark. Now lets get some gas station near me to sell some dam corn!
NickyRacerBoy is offline   Reply With Quote
