![]() Drives: Procharged 2017 2SS Join Date: Oct 2017
dropped wrench down console...
When installing my blendmount I dropped the small torx wrench (L shaped) and it fell down the console where the drivers side air vent is. perfect shot, straight down.
So the question is, how hard is it going to get it out of there. Damn, these fingers and my lack of dexterity
Retired from Car mfrs....
Use a magnet stick from auto parts store
![]() Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Glen e is right. Try a magnet stick, but the bendy type. That thing has saved my a$$ plenty. The magnets on some of these are pretty darn strong. Give it a shot. You’ve got nothing to lose and you’ll be surprised.
![]() Drives: 2016 Join Date: May 2017
The console has six screws holding it down plus the attached harnesses to the electronics. You’d have to pull the shifter knob, then the whole console will come off. It’s not super difficult, but I would probably drive around for a while to see if it rattles before I dove into tearing it apart. If it doesn’t rattle, I’d just forget about it.
Thanks collective.
I guess I'm going to drive it around for awhile and hope it doesn't rattle. If it does I'll try the magnet, and use taking apart the console as a last resort. Hope it doesn't get to that. |
#7 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Had my console out the other day. Not to terrible. 6 bolts. 4 up front under the knee pads and 2 in the rear on either side. There is a small access hole you'll see it. Unbolt all and lift console from the rear. That should give you enough clearance to fish our the driver. Note the rear of the console is tucked under the rear seat cushion and can be a PITA to lift up.
#8 | |
![]() Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
#9 | |
#10 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Tie a small magnet to a piece of nylon string and lower it slowly down in there. It will likely fall to the same place as the wrench and be able to snag it.
