Old 10-27-2017, 08:08 PM   #1
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
Exclamation Get your lugs checked !!
I have been reading on some of the ZL1 Facebook pages that the lugs on the car may be loose from the factory. I have a track day coming up so I decided to swing by Discount Tire on the way home since I got off early. Low and behold 15 of the 20 lugs on the car were loose !! Now its not like the wheels were going to fall off but only my front right wheels had fully tightened lugs. Im glad I swung by.
Just wanted to mention it to everyone. Have a great weekend
BIGTIME is offline   Reply With Quote
Old 10-27-2017, 09:16 PM   #2
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Good advice. I ended up with the clicking sound coming from the left front wheel around 1000 miles in. I took the wheel off, cleaned the mating surfaces, and reinstalled. A few miles more, the clicking returned. This time I went to the right front since it sounded like that's where it was coming from. Problem fixed once again. Then around the 4000 mile mark it seemed like I was getting the clicking again, but it was harder to hear. This time I grabbed my torque wrench and went to the rear wheels. They were both way under torqued. Almost loose even. So it's possible the fronts didn't really need to be taken off and cleaned, and just a simple retorque of the lug nuts may have solved the clicking.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 10-28-2017, 12:31 AM   #3
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
What's the correct torque specs for the lugs?
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 10-28-2017, 01:29 AM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
140#
Old 10-28-2017, 05:47 AM   #5
wnta1ss
Drives: 2017 Camaro 1SS
If you're going to be doing track days, my suggestion would be to buy your own torque wrench, and then you can easily ensure that the lugs are torqued to 140 lb/ft before each event.
Old 10-28-2017, 07:37 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the dealer is supposed to check lug torque during PDI. All of the studs stretch just a little so, recheck the lug torque numerous times during a track day. Wait until the car has cooled a bit before checking the torque.
Old 10-28-2017, 11:31 AM   #7
ScottMZ3
ScottMZ3's Avatar
Originally Posted by Glen e View Post
140#
Thanks, I'm going to stop by the tire shop today and have them check mine...JUST to be sure!
Purchased 9/23/2017
Old 10-28-2017, 02:56 PM   #8
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
This is a must. Those are going to loosen up as you spend time on the track and you're going to want to check them frequently. Do yourself a favor and put together a small plastic container with a "track kit" if you're going to track more than once.
Inspector 17 is offline   Reply With Quote
Old 10-28-2017, 09:15 PM   #9
ScottMZ3
ScottMZ3's Avatar
Got them checked...basically no movement on any of them. All at 140#. I feel better!
Purchased 9/23/2017
Old 10-29-2017, 12:27 AM   #10
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
I was a little surpised to see that he got movement on most , but some almost 3/4 turn!
Old 10-29-2017, 12:30 AM   #11
BIGTIME
BIGTIME's Avatar
Drives: 2018 ZL1
will do. What was surprising was how loose they were before the car even saw a single lap.
