Old 10-26-2017, 10:05 AM   #1
KerryNewman
Drives: BMW, Mercedes, Trans Am
2013 LS - adding a garage door opener?
My wife's 2013 LS does not have a garage door opener. Can I buy the 3 button unit and plug it in the overhead console, program it ect... will that work. The way manual describes the process to program the remote makes me think the transmitter is "in" the 3 button unit. Or is there some additional electronics needed. If so, I'll probably just get her a keychain remote. Thanks!
KerryNewman is offline   Reply With Quote
Old 10-26-2017, 10:11 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You’ll get more responses if you put it over on the Camaro5 site.
Old 10-26-2017, 10:15 AM   #3
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Buy this:
https://www.ebay.com/itm/Homelink-Un...JZpJAI&vxp=mtr
Recess it somewhere in your visor/headliner/overhead console/dash.
It needs to be powered when it is on to use it obviously, it DOES ABSOLUTELY YES maintain it's memory/rolling codes when off. Just tap a hot wire, either hot on ignition or always hot... something for example like onstar power or similar.
You can also add a 12v battery if you really want.
S2K+1LE is offline   Reply With Quote
