Old 10-25-2017, 02:05 PM   #1
PRAY
PRAY's Avatar
Drives: 2016 2SS
PRAY Performance Baby Cam H/C/IM/TB dyno numbers.
I would first like to thank Ben for all his patience and willingness to be an experiment. I learned a lot though this build. Another special thanks to Justin at Indiana Muscle Car for all his work. We were in constant contact and worked hand in hand on this build and tuning. He was as dedicated to this build as I was. They did great work.
We are still only on 58% E and I put a little to much compression in this motor. We could only get 23* total timing into this build. That is why it lays over a little bit up top. That is my fault. Another couple degrees of timing on 77-81% and I believe we would have seen 550rw out of this combo.
This car now has my STG 1 cam, my ported heads and my ported STOCK IM/TB. Graph is against bone stock. AFR was 12.5-7 on the stock pulls with 24* of timing. Car is a 17' 1LE that we set up for road course racing.
Mods:
PP ported stock heads
PP ported stock intake/throttle body
PP STG1 cam
Kooks 1 7/8" catted headers/stock cat back
RF CAI (w/ dry filter I believe)
Name:  Ben final dyno.jpeg
Old 10-25-2017, 02:10 PM   #2
ss_rob
Drives: SS
I need this heads and cam package
ss_rob is offline   Reply With Quote
Old 10-25-2017, 02:12 PM   #3
PRAY
PRAY's Avatar
Drives: 2016 2SS
I can do that for you Sir.
Old 10-25-2017, 02:12 PM   #4
TEEZYSS
Drives: 2016 CAMARO 2SS
PRAY FTW!!!! Straight up ground pounder!!!!
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248
PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664
GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next...
TEEZYSS is offline   Reply With Quote
Old 10-25-2017, 02:20 PM   #5
PRAY
PRAY's Avatar
Drives: 2016 2SS
Cam is very low 220's/barely 230's.
Old 10-25-2017, 02:22 PM   #6
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Very impressive, didn’t think porting would Open it up that much, can we get a video of how the car sounds? Does the cam work for procharger?
MP3BOOSTED is offline   Reply With Quote
Old 10-25-2017, 02:26 PM   #7
PRAY
PRAY's Avatar
Drives: 2016 2SS
I will see if I can get some vids up. I think I was sent one or two.
I wouldn't run this cam with a PC. It was designed around my heads and being N/A. I have other grinds that will work well with a PC.
Old 10-25-2017, 02:33 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
Stock converter friendly?
Old 10-25-2017, 02:37 PM   #9
PRAY
PRAY's Avatar
Drives: 2016 2SS
That's what I designed it around. I will have to get with IMC to see what they have it idling at. I think it will idle fine at 700rpm. I have used these specs on stock converter A6 cars without issues. I have actually gone 4* larger stock converter A6 cars but there is a little tugging at idle. That is why I designed this cam. The A8 converter is a little looser than the A6.
I will shoot you the specs in a PM.
Old 10-25-2017, 02:37 PM   #10
MP3BOOSTED
MP3BOOSTED's Avatar
Ah okay understood, well standing by to hear that idle!! I was going to get phastek aggressive cam but I plan on procharging the car very soon so might just go semi agressive, would like to hear how your car sounds though.
Old 10-25-2017, 02:42 PM   #11
PRAY
PRAY's Avatar
Drives: 2016 2SS
If you want to hear the cam in my car then head over to my FB page. I have an idle vid on there. I am sure they sound about the same due to the lobe sep and compression.
Old 10-25-2017, 02:57 PM   #12
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
So a little less compression and more timing and the power will carry further on this combo? I am still debating a package like this or a Maggie next season.
Old 10-25-2017, 03:05 PM   #13
PRAY
PRAY's Avatar
Drives: 2016 2SS
Yes, I believe so. The TQ Coefficient tables could possibly help but some small adjustments were made and not much changed. We are running into KR limitations up there right now. On pump gas we didn't run into that flat spot. It pulled up to 6,500-6,600 without the lay over on only 17* of timing. We were still working through the tuning at that point and just moved on to E. I believe we are up against the computer and possible some frequency issues up there. It is only in two cylinders that it picks up but we didn't want to push the motor. No need with the power we are making now. Mine shows KR in the same exact two cylinders when it pops up. My DCR ended up lower than this build. If we could get the E content up I am sure it would hold the proper timing and wouldn't lay over any more. I designed this package and picked my final DCR based off of maximizing tq and this not being a drag motor but a road course car. Adjustments can easily be made for future builds.
Old 10-25-2017, 03:44 PM   #14
Snowblind
Snowblind's Avatar
Very impressive curves and gains. That's in the ballpark of the FI guys....take dem boys to da whippin shed and proceed to open up a can...
