Old 10-23-2017, 02:56 PM   #1
Metsfan
Metsfan's Avatar
Drives: 2016 2SS A8 w/ NPP, MRC
Is this normal wear?
So I had to replace my rear tires around 15k because of a nail in them. I went to get my North Carolina state inspection done yesterday and they failed me because the outer edge of the front have no tread according to them. They currently have 18k miles on them. The center and inner part of the tires still have tread. When you compare them to the rear though, I can see what their talking about. Maybe I'm wrong on this, but I feel like the tire still has plenty of tread. Is this normal wear for these tires? I don't have any alignment issues or noticed anything weird, so I don't know if there's something wrong or if it's just normal. TIA for any help.
Metsfan is offline   Reply With Quote
Old 10-23-2017, 05:46 PM   #2
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
looks normal to me... I have 22k miles on my tires and not much left (and I hear that is pretty good mileage out of the goodyears)
According to your pic, NONE of the tire sections have any tread... yet it is ABOVE the wear bars...so.... I think it should pass but?
I'm not sure if you can do anything about it. we don't have inspections over here... and no rain, so I plan to take mine down till they are slicks!
crazydmc is offline   Reply With Quote
Old 10-23-2017, 06:12 PM   #3
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Normal.
But above wear bars.... that's a fail?
And Dude....wash your wheels
Old 10-23-2017, 06:12 PM   #4
Metsfan
Metsfan's Avatar
Ok thanks for your input! They rated the inner and center as having enough tread, but not the outer so I just thought it was strange. I went ahead and ordered new tires anyway since I figured there was no way around it. Definitely not getting the good years again.
Old 10-23-2017, 06:14 PM   #5
Metsfan
Metsfan's Avatar
Normal.
Lol yeah they've been neglected lately because every time I have time, it's been raining.
Old 10-23-2017, 06:25 PM   #6
enzia35
Drives: '16 Garnet Red 1SS
That does seem like abnormal wear. Here's a picture of them new:
https://www.tirerack.com/tires/BigPi...wall=Blackwall
'16 Camaro 1SS
'18 Miata GT
Old 10-23-2017, 06:34 PM   #7
Metsfan
Metsfan's Avatar
I looked at that picture today. The wearing on the outside is what's concerning to me. I don't know if this is normal considering the miles on them or if have another issue going on since the inner and center have tread left. When I got the rears out on, the fronts were looked at too and they didn't notice anything unusual so I'm thinking it would normal wear?
Old 10-23-2017, 06:54 PM   #8
enzia35
I'd definitely check the alignment at least.
'16 Camaro 1SS
'18 Miata GT
Old 10-23-2017, 08:45 PM   #9
crazydmc
ummmm
crazydmc's Avatar
I was going to agree that the outer most section (and inner most section) are worn more than the middle of the tire (likely related to how hard you are cornering)
if you drive like a grandma then I would say there may be an alignment problem otherwise it is hard to not take the edges off the tires (even with perfect alignment).
the outer edge of the tire has a shallow tread pattern, so the "tread" disappears like yours well before the tire is actually worn out. It is a bummer that there is no way to tell how much rubber you have left at the sides (i.e. no wear bar) so they can just say FAIL I guess.
Old 10-23-2017, 09:30 PM   #10
Risky Justice
Risky Justice's Avatar
Drives: 2016 Camaro 2SS M6
Like others have said, could be spirited driving around corners, or it could be that you need an alignment. Personally, my tires always wear faster on the outsides, because I like to take corners like a bat out of hell.
I wish they would do vehicle inspections around here...at least for tires/safety. I have seen some scary shit.
‘16 Camaro 2SS M6 - RotoFab CAI, Soler Performance TB, E85
8.102 @ 89.85 MPH (bone stock)
Risky Justice is offline   Reply With Quote
Old 10-23-2017, 09:43 PM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Then you need to get an alignment and dial in a little more camber
Eric SS is offline   Reply With Quote
Old 10-23-2017, 10:21 PM   #12
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Have you noticed a large drop in dry traction. Like spinning all through 2nd and 3rd gear? Its like when the stock goodyears hit a certain milage the compound turns to where it looses all traction.
cmitchell17 is offline   Reply With Quote
Old 10-23-2017, 10:36 PM   #13
Metsfan
Metsfan's Avatar
I do the occasional spirited driving around corners. Nothing crazy though. I haven't noticed any pulling to one side or the other or any loss of grip. I did get a coupon the other day from my dealer for a free alignment check so I may take them up on that. The only thing I've noticed recently that's different is I'm getting a slight vibration when when I accelerating or decelerating. From what I read though in the forums it may be the torque converter, so I need too get that looked at.
Old 10-24-2017, 04:57 AM   #14
Quiksilver16ss
Quiksilver16ss's Avatar
Drives: 2016 camaro 1ss
The f1s don't have much side tread when their brand new. I'd replace em
now for sure.
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels
Quiksilver16ss is offline   Reply With Quote
