Old 10-20-2017, 10:07 PM   #1
CamaroDude2ss
Drives: 2016 2SS Silver w/ Black Stipes
Smile Stainless Works O2 Sensors
Hello Everyone - I'd like to add Stainless Works headers and full exhaust to my 2016 2SS A8 with NPP. However, with SWs high flow cats I'm worried about throwing the CEL. And I don't want to have my car tuned and void my warrenty.
I called SWs and the customer service agent said installing O2 simulators from Big Daddies Garage will keep the CEL from coming on. Has anyone successfully used these items..?
Any help & feed you can provide is greatly appreciated...!
CamaroDude2ss is offline   Reply With Quote
Old 10-20-2017, 11:35 PM   #2
jaysonstuart
jaysonstuart's Avatar
I haven't heard of this but I'm interested to know as well since I currently have a CEL on due to headers/exhaust.
jaysonstuart is offline   Reply With Quote
Old 10-21-2017, 08:08 AM   #3
jimmypop13
Drives: 2016 camaro ss
I have that setup. It definitely caused a CEL. If o2 sims came out that worked that would be awesome but so far I haven't heard of any. I also set off a post catalyst fuel system too rich code though that I'm not sure if the big Daddy o2 sims could fix
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 07-19-2018, 02:17 PM   #4
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
Big Daddy site states it clears the two post cat codes. PO420, PO430
http://www.bigdaddiesgarage.com/straight-cel-fix.html
gmw0181 is offline   Reply With Quote
Old 07-19-2018, 05:11 PM   #5
Chef-j
Drives: 2018 Camaro 1SS
Its been using in many different cars who runs test pipe (no cat). You can also find in Ebay or Amazon.
I personally used on S2000 and it worked. You wouldnt throw code with HFC tho.
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 08-06-2018, 09:07 AM   #6
gmw0181
gmw0181's Avatar
I had the Stainless Works cat back system installed. I get the PO420 code. When I reset it does not come back until I drive the car hard. I drove on vacation 900 miles one way with no code until I dove it hard on curvy roads. Camaro SS runs fine and sounds good.
I ordered the Big Daddy Simulators, I will let everyone know if it works.
2017 Camaro SS
Diablo Sport 93 tune
CAI
Old 08-06-2018, 04:15 PM   #7
bullet3z
Drives: 2018 1SS 1LE
2017 Camaro SS
CAI
So you still have the factory cats? If so then it sounds like you might have an exhaust leak. I took out my secondary cats and my check engine like does not come on.
bullet3z is offline   Reply With Quote
Old 08-11-2018, 12:52 PM   #8
gmw0181
gmw0181's Avatar
PO420 Code
Yep you were correct. I went back to the installer a third time and they removed the exhaust and corrected a leak by the driver side cat. The leak was only when it was cold and very little when hot. Once I showed them the leak on a cold start they came in during off business hours to fix it.
Thanks for the info it helped me a lot. No more CEL.
Old 08-12-2018, 02:36 PM   #9
bullet3z
That is good to hear. Glad they got it fixed.
