Old 10-20-2017, 12:31 PM   #1
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
pics of our cars with 18" track wheels?
Seriously considering switching to 18" from 19" track wheels for cost reasons. Anyone have any photos of what our cars look like with an 18" setup on it? I'm aware that some grinding of the strut would be needed. with my 5mm spacers and camber plates it won't be much though. Thanks.
Eric SS is offline   Reply With Quote
Old 10-20-2017, 01:25 PM   #2
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Beast mode. 18x10 ET25 running 285/645 P-zero DH take-offs.
Provoste is offline   Reply With Quote
Old 10-20-2017, 01:46 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Awesome. Thank you! That is beast mode with those tires. Is that equivalent to a 40 series tire if you convert slicks to aspect ratio?
Old 10-20-2017, 01:55 PM   #4
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
This is 18x11 square, with 315/30-18. The car is lowered nearly an inch, but with the smaller overall diameter the fender gap ends up about the same as stock.
I got one close-up shot, and one at distance. heh
rotis is offline   Reply With Quote
Old 10-20-2017, 01:59 PM   #5
Eric SS
#becauseracecar
Eric SS's Avatar
Thanks Rotis. If I'm not mistaken you have offset struts right? I'd love to go square 18x11 but I'm sure I'd have to do a ton of grinding even with my 5mm spacers and camber plates
What offset are your wheels?
Old 10-20-2017, 02:03 PM   #6
rotis
rotis's Avatar
Yes, offset struts. No way these would fit under the stock SS fenders without gaining more room on the inside.
The wheels are +43, I run a 20mm spacer in front for an effective offset of +23. The picture is at -3.7deg of camber.
Old 10-20-2017, 02:26 PM   #7
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
Where are you getting your takeoffs? How long do they typically last you?
RXtacy is offline   Reply With Quote
Old 10-20-2017, 02:28 PM   #8
Provoste
Provoste's Avatar
No, acctually somewhere between a 30-35 series sidewall.... closer to 285/30!
OD for 285/645 18: 25.2
OD for 285/40 18: 27.0
OD for 285/35 18: 26.1
OD for 285/30 18: 24.9
Old 10-20-2017, 02:37 PM   #9
Provoste
Provoste's Avatar
John Berget Racing Tire. The P-Zero's are fantastic, on the last set- I ran 3 days at Putnam Park, and 2 days at Mid Ohio. Probably 18-20 HC's in all. They never completely gave up, though the last few sessions @ mid ohio, they had lost their best for sure. $120 per tire. I have a fresh set for VIR next month!
Old 10-20-2017, 02:51 PM   #10
RXtacy
RXtacy's Avatar
Wow that's better life than I was expecting, and definitely hard to argue with the price!
Old 10-20-2017, 03:31 PM   #11
Magsz
Drives: 17 1SS 1LE
For the layman...
What is the benefit of a smaller rim/tire combination besides cost?
Magsz is offline   Reply With Quote
Old 10-20-2017, 03:40 PM   #12
RXtacy
RXtacy's Avatar
Originally Posted by Magsz View Post
For the layman...
Lower unsprung weight = quicker acceleration
Smaller diameter (better effective gear ratio) = quicker acceleration
Old 10-20-2017, 04:12 PM   #13
Provoste
Provoste's Avatar
Exactly. All VERY good things, and when combined... makes a very noticeable difference on track.
FYI, the 285/645 18 is a 7.35% smaller rear OD than stock. That’s a BIG difference in gearing which rocks on track!
Old 10-21-2017, 10:42 AM   #14
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
For the layman...
You also lower both the sprung mass CG height and the geometric roll centers - without affecting things like suspension geometry and half-shaft angularity at all.
Norm
