![]() Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold Join Date: May 2017
Headliner coming apart
Just noticed today that my headliner is coming apart near the rubber window seal on the passenger side. Located nearly at the center top, about 3 inches. I will take a pic when I get a chance, but looks like it's not a tuck in issue. Anyone else has this problem? Car (1LE by the way) has been solid otherwise
![]() Drives: 2017 Camaro 2SS, MRC, NPP, Join Date: Jul 2016
I have this issue. Dealership said they had to replace the headliner.
Full Fledged Member
Same here, been waiting a few months for a new headliner
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2 |
#4 | |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I tweaked the headliner at this point and somehow managed to tuck it in the rubber seal. I do not have an issue since. Lets hope it stays this way. In any case, I will not take it to the dealer for 2 main reasons even if it happens again: 1.) Course of work involves dismantling the windshield - I prefer to leave it as it was installed at the factory. Windshield re-installations can leave bad traces and often go bad (I.E. dashboard damage, adhesive overflows, Etc.) 2.) It does not guarantee to solve the issue, since the problem is most likely the shape of the headliner and this is not expected to change when replacing for the exact same Part. If headliner issues worsen over time, I prefer to take it to a professional interiors fabricator to find a fix - these guys usually have good "out of the box thinking" solutions in such cases. |
![]() Drives: Camaro 2LT Join Date: Jun 2018
Can we see some images? Can extra glue resolve this issue?
![]() Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
I had mine replaced at the dealership for the same issue. They replace it with a different headliner that measures out correctly. Problem is the stock headliners were made too narrow. It's not a glue issue. Replacement is the right size.
Yes, the windshield needs to come out to fix it. Nobody would be able to tell it's been replaced. |
#7 |
![]() Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Out of curiosity, sunroof or no?
#8 |
no sunroof on mine
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
yup mine also goodluck dealer said no fix
#10 |
#11 |
yup probably just take to my custom upholstery shop and have em do a suede one to match my steering wheel and shifter and knee pads
#12 | |
With most dealerships you end up disappointed. |
#13 |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I had the headliner replaced in my 16. They chipped the drivers door edge, scratched inside the passenger door jamb and the right rear rattled after. I’d really weigh my options if confronted with this on my 18.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
