10-15-2017, 02:09 PM | #1 |
Drives: 2019 Chevy Camaro ZL1 A10 Join Date: Sep 2017
Oxygen Sensor Extension Harness Help Please
So I just ordered some ARH 2" longtube headers(intermediate system) with the Borla Attack cat-back exhaust. I believe I'll need Oxygen Sensor Extions Harnesses. Where can I find them online to purchase?
Also is there any info out there on how to install the ARH Longtubes on the new ZL1 Camaro? Any help is much appreciated Thank You. |
10-15-2017, 03:32 PM | #2 |
ARH sells the extensions. At least they do for 5th gen Camaros and Corvettes. They may not be on their site in which case you can call them and ask. (Usually though they're in a little drop down box when you option out which Header system you want).
Install shouldn't be that bad, though 2" are a bit harder to stuff in, but it's ARH, they're top notch and the fitment will be perfect once installed correctly. Those who have installed can give you some tips/pointers when installing them. What are you planning on doing tune-wise? |
10-15-2017, 04:20 PM | #3 |
Thank you for the tip Can'tHavetooMuchHP. I plan on getting an intake, pulley and tune after I put on the exhaust. I don't believe I have to tune the car if I just install full exhaust. Correct me if I'm wrong.
10-15-2017, 06:17 PM | #4 |
10-15-2017, 09:26 PM | #5 |
Ok I better get my 2.3 pulley and intake as well for the Tune. Thanks
10-16-2017, 03:20 PM | #6 |
I just got a call from American Racing Headers responding to my email. They said the Oxyegen Sensor Extension harnesses comes with the order in the box. No need to buy extensions. Problem Solved!
No I just got to figure out how to install these Beauties. I'm sure I'll have to unbolt the engine from the Motor Mounts and jack it up on one side a little bit. Also disconnect the Steering column. |
10-16-2017, 03:23 PM | #7 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
I got mine from kooks
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
