Old 10-15-2017, 01:09 PM   #1
jrs580
jrs580's Avatar
Drives: 2016 2ss
Electrically controlling blower bypass valve
What Would it do from a tuning standpoint if you had the ability to keep the bypass valve open even under low vacuum levels, rendering the blower ineffective? What I'm getting at is having a switch to control bypass?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 10-15-2017, 01:28 PM   #2
Omega
Drives: G8
Depending on the type of SC you have, there is already such a thing.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 10-15-2017, 05:37 PM   #3
jrs580
jrs580's Avatar
Drives: 2016 2ss
I have a whipple. Is it an accessory of sort?
Old 10-15-2017, 08:14 PM   #4
Omega
Drives: G8
You already have one then.
What are you trying to accomplish?
Old 10-16-2017, 07:31 AM   #5
jrs580
jrs580's Avatar
Drives: 2016 2ss
I want to flip a switch inside and force that valve open even under heavy throttle, disabling the blower. Like a teen driving mode, or in my case a traction mode when it gets under 55 degrees outside.
Old 10-16-2017, 07:54 AM   #6
Omega
Drives: G8
That could be done by adding a solenoid to the pressure side hose of the bypass valve. With the vent closed it would act as normal, when triggered it would vent and the valve could be forced open by the compressed SC air. Take the hose off and take it for a spin, no boost and you'd be in business.
Old 10-16-2017, 11:08 AM   #7
nick_casper
nick_casper's Avatar
Drives: 16 2SS
I never thought of this but maybe we could use the bypass valve to limit power in first and second gear to get better launches.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 10-16-2017, 01:12 PM   #8
jrs580
jrs580's Avatar
Drives: 2016 2ss
I just zip tied the bypass valve open and nothing went wrong, no boost...basically factory again.
Old 10-16-2017, 01:51 PM   #9
Omega
Drives: G8
Nice!
This is the solenoid most companies use for boost management.
Plumb it, wire it up (don't forget a fuse) and you're good to go!
https://rover.ebay.com/rover/0/0/0?m...2F161990549423
Old 10-16-2017, 02:42 PM   #10
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Whipple has software they used for S550's not sure about our Chevy's though.
http://www.mustang6g.com/?p=8310
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
