Old 10-15-2017, 09:08 AM   #1
JFM-jr
JFM-jr's Avatar
Commanding fuel pump on
Im looking to put some better ethanol content fuel in the car and dont wanna drive it around to empty whats in there already. I am disconnecting the fuel supply line over the intake manifold to drain the fuel into a can. Anybody know what i need to do here in HPT scanner to command the fuel pump on? Not sure what to do I know theres the in tank lo side and the high pressure pump under the intake manifold.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 10-15-2017, 09:17 AM   #2
JFM-jr
JFM-jr's Avatar
Dam pic is huge and sideways lol
Rotofab
11.0@124.9
Old 11-03-2020, 03:05 PM   #3
teesee150
Drives: Camaro
Did anybody get this to work. Just tried it on Hptuners myself and fuel pump does not turn on.
teesee150 is offline   Reply With Quote
Old 11-03-2020, 08:51 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I was able to use the fuel pump activation through HP Tuners. Worked fine.
Old 11-05-2020, 02:45 PM   #5
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
How? What steps did you take?
aronSlusa is offline   Reply With Quote
Old 11-05-2020, 03:24 PM   #6
6spdhyperblue
Drives: 2SS 1LE
I’d like to know this as well. And are you disconnecting the fuel line above the IM and filling a jug?
Old 11-05-2020, 07:55 PM   #7
teesee150
Drives: Camaro
I had my Camaro on a lift so I disconnected the line just in front of the fuel tank under the car. I had a scrap line with the correct fitting that I cut off that I stuck in the line with some rubber hose to run to a gas can.
Old 11-08-2020, 08:37 AM   #8
Joshinator99
Moderator
Here you go.
