Old 10-13-2017, 05:51 AM   #1
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
cold start vs exhaust crimp sound
I'm going to say it.......The cold start for the first (5 sec) on the 2ss sounds like a combo of a plastic toy horn and a fart noise. I know the lambos and ferrrari do it too, but am I the only one willing to admit that the old-school deeper controlled start-up tone sounds much much better?
Does anyone know if removing the crimp will change sound to more of what the Gen5 sound had??
I do have a flowmaster AMT axleback, and it improved cold start a bit, (and immensely better at warm idle) but if you compare the start up to the gen5, then you know what I'm talking about.
So I understand that the exhaust crimp makes no difference in power, as per the mishimoto article below...
https://www.mishimoto.com/engineerin...he-crimp-myth/
BUT does anyone know if makes a difference in sound?
2016 SS M6
MR-02 is offline   Reply With Quote
Old 10-13-2017, 06:00 AM   #2
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
This is what my gen 5 sounded like - same set up - cold start was a ton better
2016 SS M6
Old 10-13-2017, 09:29 AM   #3
Zzzato
Bigg Balls
Zzzato's Avatar
Drives: 2024 Red Hot 1SS
My cold start sounds much better than that
2017 Red Hot 1SS 8A..... Sold for a minivan
2024 Red Hot 1SS 8A.... No mods ..... yet
Zzzato is offline   Reply With Quote
Old 10-13-2017, 10:12 AM   #4
enzia35
Drives: '16 Garnet Red 1SS
Enclosed space is the best for exhaust videos! /s
'16 Camaro 1SS
'18 Miata GT
Old 10-13-2017, 01:23 PM   #5
2slow95vert
Drives: 2016 2SS Hyper Blue
Have to disagree. I LOVE the cold start. Wish the exhaust always sounded like that
2slow95vert is offline   Reply With Quote
Old 10-13-2017, 01:30 PM   #6
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
My '16 2SS sounded great at startup; it did have dual mode exhaust. I did test drive a non-NPP SS and it did not sound anywhere near as good on startup.
nancygrl is offline   Reply With Quote
Old 10-13-2017, 03:24 PM   #7
parish8
Drives: 17 SS a8
Part of the start up sound is cat warm up. I think it pull a bunch of timing or something to heat up the cats. If you turn that off it starts like a normal car. You really notice the sound with no cats.
Old 10-13-2017, 06:27 PM   #8
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Parish8 , Do you mean turn it off with a tune? Thanks for the info, don't know why my link isn't working, I'll try again.
2016 SS M6
Old 10-13-2017, 07:50 PM   #9
1slowssm6
Drives: 2016 1ss m6 Camaro
yes with a tune,since the tune my car cranks up like a normal car,none of that tinny raspy startup and then calm,it just cranks and is calm.
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step.
Best 1/4 mile of 11.2@122mph
1slowssm6 is offline   Reply With Quote
Old 10-13-2017, 09:22 PM   #10
JFM-jr
JFM-jr's Avatar
Id love to know what tables to go into and change in my HPT
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 10-14-2017, 07:34 PM   #11
MR-02
MR-02's Avatar
Drives: 2016 2SS M6
Im so glad you know what Im talking about! Can you give details more on what tune, or how to make it start up without that "tinny rasp"/cold horn fart sound? Just crank and calm is all it should be-basically warm start sound on a cold start. Help!
2016 SS M6
Old 10-14-2017, 08:33 PM   #12
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
From what I can see the only timing modifier at cold ECT is just cranking spark? unless I'm missing something, I don't see any timing modifiers for cat lightoff. Now there is start of injection timing modifiers for cold start?
I agree, I think the exhaust is way too loud for a stock exhaust at startup, it also sounds pretty bad to me. I love the way it sounds when the valves are partially open at half throttle, but at WOT to me the NPP sounds pretty bad, raspy and annoyingly loud.
cmitchell17 is offline   Reply With Quote
Old 10-15-2017, 11:16 AM   #13
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
No..I have been saying it all along. Some say it doesn't have the old school sound because its an aluminum block and not iron. I say not the case but some of it is the VVT cam timing and maybe the firing order, and port FI. If it were do to it being an aluminum block then the 69 ZL1 which also came with an all aluminum block would also have a similar sound. But the old ZL1 also has the old school rumble. Also a lot of the old school car came with fiberglass packed mufflers. I have yet to hear any of ours with packed mufflers. Most performance mufflers for our cars are just hollow chambered mufflers which I think gives it the hollow sharp raspy sound that sounds like shidt when sitting in one spot just revving it, but sounds totally different and pretty good when going down the road under load especially when shifting through gears in a stick. Also listen to one of our cars with a performance cam upgrade. You will see its starting to have the old school rumble. So to sum it up I would say its sound is mostly do to our hollow exhaust and camming.
Marty McFlew is offline   Reply With Quote
Old 10-15-2017, 01:42 PM   #14
cmitchell17
Is the NPP exhaust hollow? I thought I saw pictures of someone cutting open an NPP muffler on a corvette and there being fiberglass packing in it?
I completely agree, it sounds really good at mid throttle under load, but at WOT or startup sounds pretty bad and unrefined.
