![]() Drives: 2016 Camaro 2SS Convertible Join Date: Oct 2017
NOS with Maximizer4 TPS
I've searched through many of the different threads, and I keep coming up with everything but what I'm looking for.
I have a 2016 2SS Conv. I recently decided, "Hey, lets put some NOS in this thing". So I got the kit from Nitrous Outlet and got it plummed in. Then I found a Maximizer4 Controller and got it all hooked up to the point of the TPS... crash... brick wall. Im certain many, if not all, of you have hit this same brick wall. So Im asking, Which wire do I want to connect to at my TPS? I have a 5 wire connection, my choices appear to be black, black with red pin stripe, black with white pin stripe, blue with white pin stripe, and yellow. Thanks to one of the threads I discovered the green wire at the coils and my rpm's are registering great. I just really like the added security of the throttle position sensor being in the mix doing its job. |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
No TPS voltage on the 2016, serial data from the TB for position. You can possibly use a CAN to Analog converter from Lingenfelter, check their website.
Drives: Anything I want Join Date: Oct 2008
Thanks for the info. I will look into that.
Drives: 2016 camaro ss convertible Join Date: Dec 2016
sorry if I come off as a newb but I was using a basic zex management box kit on mine and it required a tps signal. what I was told from a few other people that are on the forum that used nitrous was to use the yellow stripe wire off the pedal for a tps signal and n it worked fine for many bottles
