Old 10-12-2017, 06:39 AM   #1
shinysun
Drives: 2016 Camaro SS
Temp drop. Whipple vs Maggi
I got my car Whipple SC with meth injection, and inject 50/50 of meth and water.
One of my friends has the similar system, but Maggi. Almost the sam boost.
However, when he starts to spray , the IAT drops from 120 to around 90 while mine is going up little.
I assume we are sprying almost the same rate.
Is it from a kind of structural difference btw the 2 chargers?
shinysun is offline   Reply With Quote
Old 10-12-2017, 06:40 AM   #2
Omega
Drives: G8
Are you spraying the IAT?
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 10-12-2017, 07:33 AM   #3
shinysun
No. Just before TB
Old 10-12-2017, 07:38 AM   #4
Omega
Drives: G8
Originally Posted by shinysun View Post
No. Just before TB
That's your problem.
If you spray after the IAT (inlet air temp) the sensor has no idea what your doing. Not horrible, but your not reaping all the benefits. By spraying the IAT, you can trigger more timing and if you run out it WON'T trigger more timing and helps protect the engine.
Old 10-12-2017, 02:00 PM   #5
toohighpsi
Drives: 2015 C7 Z06 M7
The IAT should be located after the SC (I know it is on a Maggie) so it should be able to register the change if there is one when injecting pre throttle body. Did the Whipple have a breakout harness to change the location if the IAT from the MAF to the post intercooler location?
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 10-23-2017, 04:58 AM   #6
laynlo15
Drives: 2022 Lt1 A10
My IATs are about 115 before my 1/4 pass and about 120 in the traps. Staying plenty cool
