![]() Drives: 2016 2SS M6 NPP MRC Join Date: Jul 2016
A/C not working at idle
Just an FYI as it does seem like this could be something more people run into and maybe this story will save you an extra week or two of time spent in the shop.
My car just tipped 37.4k and the ac stopped working when the car was idling. Once you started moving it would work again. The tech said there was a blockage in the system. First attempt: replace condenser for $1350 - problem still there Second attempt: replace some valve in the ac system for $570 - problem still there Third attempt: contact gm engineering support and they have 4 other cases on camaros with the same condition. Turned out to be the cooling fan. Another $840. Just before this problem at like 36.5k miles I had a coolant line that was leaking and the replacement was $430. My extended warranty has already paid out more than I paid for the warranty and I still have 62k miles to go.
376 cubic inches of fun
Aren't you glad you bought the extended warranty!
Yeah you know it!
I have never bought an extended warranty and barely ever had to use a factory warranty. I guess I was due for a vehicle with problems. Still it's completely worth the hassle for such a fun car. |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
The tech working on the car seems to not be that "skilled" should we say to be nice. What your describing has nothing to do with anything he has blamed and replaced.....you have cooling fans failing, or at least one of a dual fan which you should have. This does not draw enough air past the condenser when sitting still so as the heat cannot be exchanged the AC cannot work. Replace the cooling fans assy and all will be fine. Even a basic AC tech would have easily diagnosed this.
Good Luck!! |
