Old 10-09-2017, 02:58 PM   #1
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
Track Day Tire Question
Seems like I can't catch a break with my car. Just noticed a screw in my right rear tire. Took the tire off and sprayed soapy water on it, bubbling is very very minimal. The tire is slowly losing air but I filled the tire a week and a half ago (psi was 26) and it has remained at the 33 psi since then. I plan on going to get a plug put in eventually because the tires have a lot of life left in them. Would you guys trust a plug on the track or would I be better off just buying a new set of rears? I don't plan on tracking the car until spring.
hms2488485 is offline   Reply With Quote
Old 10-09-2017, 03:22 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
The tires will likely be worn out by springtime since you're down yonder where you can drive on them all year.
I had construction nails go into each rear tire, 3 days apart from each other. I plugged the first one, but once I got the 2nd nail I said screw it and bought a new pair of rears. Personally I wouldn't want to track on a plug, the centrifugal forces at straightaway speeds is way more than cruising down the interstate and I have my doubts whether a plug would be safe enough.
Old 10-09-2017, 04:27 PM   #3
Yanbags
Yanbags's Avatar
Drives: '17 SS 1LE
I've always had bad luck with nails/screws and tires...I've tracked both of my previous cars with just plugs in the tires several times with no issues.
Haven't had any nails or screws bother this car yet, fingers crossed
Yanbags is offline   Reply With Quote
Old 10-09-2017, 07:02 PM   #4
TrackClub
TrackClub's Avatar
Personally don't want to ponder "what ifs" with a plug in while pushing the car on a track. But that's just me: I tend to be conservative.
BTW: that's an interesting 1LE pic in your sig Yanbags
Old 10-09-2017, 07:05 PM   #5
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Originally Posted by TrackClub;9934370[B
]Personally don't want to ponder "what ifs" with a plug in while pushing the car on a track.[/B] But that's just me: I tend to be conservative.
Totally agree. Even if you were able to drive as fast as you want and not have a problem, in the back of my mind I would be constantly thinking about it and being distracted by the "what ifs."
A lot less $ to replace a tire than to replace the potential damage that a blown tire can do. Just my 2 cents though.
FlowForm_Wheels is offline   Reply With Quote
Old 10-09-2017, 07:28 PM   #6
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Get an inside patch.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 10-09-2017, 09:36 PM   #7
TEX1LE
Drives: 2017 1LE - Blue
I had a patch plug on my rear left tire and did 3 track days and about 4 autocross events without any issues
TEX1LE is offline   Reply With Quote
Old 10-09-2017, 10:59 PM   #8
NickyRacerBoy
Drives: 1LE
😀100 agreed.
NickyRacerBoy is offline   Reply With Quote
Old 10-10-2017, 02:17 AM   #9
TrackClub
TrackClub's Avatar
Is there any other patch?!
Old 10-10-2017, 07:03 AM   #10
pbsinternet1le
Yes, pirates use an eye patch.
2017 1LE Hyper Blue
Old 10-10-2017, 09:48 AM   #11
Yanbags
Yanbags's Avatar
Drives: '17 SS 1LE
Nobody has taken any track photos of my 1LE yet
Old 10-10-2017, 02:57 PM   #12
hms2488485
hms2488485's Avatar
Thanks for the input guys. I'll ride it out for now. I figured I'd need new tires this spring anyway, unless SCCA drops another track day at Charlotte Motor Speedway
Old 10-10-2017, 07:54 PM   #13
Marshsram
Drives: 6mt
If you have a patch from the inside there is zero concern. I personally do not have any issues with running a even a snake plug but most people seem to be *ultra* conservative when it comes to tires. FWIW I've tracked on plugged (not patched) tires countless times without issue. It seems like construction never ends around my house and at least once every other month I pick up a nail. If I had to buy a new pair of tires every time I damaged one I would be millions of dollars in debt.
Worst case the plug slowly leaks and you'll see it on TPMS before the tire goes flat and damages itself. It's 2017 and tires don't just catastrophically fail out of nowhere, these days... unless it's a Pirelli and you're an F1 driver.
Marshsram is offline   Reply With Quote
Old 10-10-2017, 09:45 PM   #14
TrackClub
TrackClub's Avatar
Is there such a thing as a patch on the outside (apart from a pirate patch as already pointed out above)? Even (well done) plugs will have an inside patch. Lastly, F1 and NASCAR and pretty much any other racing series. Hmmm...I wonder what a common denominator is here?
But ya, for street use zero issue in my book.
