10-09-2017, 10:20 AM | #1 |
Drives: 2018 HBM SS 1LE Join Date: Jun 2017
Is this NPP rattle?
Noticed a new sound last night. Driving about 70 mph or so, sixth gear, rolled onto the throttle a bit when switching lanes and got a very distinct rattle that sounded like it was coming from my right. Didn't really sound like it was behind me, but whatever. Reproduced it reliably several times, and found that if I kept pushing down on the throttle it would go away at higher throttle positions.
I'm running the exhaust in track mode, so it's open most of the time but I think it closes at cruise in higher gears at lower throttle positions, yes? Is what I'm hearing probably just the 'infamous' NPP rattle? |
10-09-2017, 10:42 AM | #2 |
Drives: HB 2SS Join Date: Apr 2017
Most likely it. Just do a cold start next morning and listen in stealth mode. You'll hear it in an instant.
10-09-2017, 12:46 PM | #3 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Definitely the NPP rattle. Even in track exhaust mode, in 6th gear light throttle the valves still close to prevent droning on the freeway. If you apply more throttle to accelerate you'll hear a loud rattle from the back of the car (mine is also on the right side). If you accelerate hard enough or downshift, the rattle will go away because the valve will open up.
03-08-2018, 06:36 AM | #4 |
Drives: 2017 2SS Convertible Join Date: Apr 2017
Does the chevy dealer "fix" with epoxy work?
03-08-2018, 07:11 AM | #5 |
Drives: 17 SW 1LE Join Date: Jun 2017
if it doesn't then you get a new exhaust.... so win win....
03-08-2018, 10:08 AM | #6 |
Drives: 2018 2ss 1le Join Date: Jan 2018
how common is this problem?
03-08-2018, 10:20 AM | #7 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I had it. Drove me nuts. Took it to my dealer. They had a bulletin on it but we were both sceptical as to its ability to resolve the issue. So we opted out for an easy fix: pull the fuse. No more rattle. No drone issues either with baffles open all the time.
03-08-2018, 10:32 AM | #8 | |
Drives: 2018 1SS 1LE Join Date: Aug 2017
Sorry to ask this. What fuse did you pull? Also by pulling the fuse do you lose the stealth mode? I would assume that by pulling the fuse, you no longer have the use of the NPP system? Again, sorry to ask. I see this tern come up and I never really understood it completely. I thought is was something that was done to the 5th gens and the older Vetts. |
03-08-2018, 10:41 AM | #9 | |
I don't miss other set ups at all. |
03-08-2018, 11:02 AM | #10 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
only for about a month then it returns. Ask me how I know. I also did the fix myself to insure it was done properly and it still returned.
MJK3888 Instagram Link
03-08-2018, 12:14 PM | #11 |
03-08-2018, 12:18 PM | #12 |
"M1SS1LE"
03-11-2018, 11:12 AM | #13 |
Drives: 2018 SS 1LE Join Date: Jul 2017
Almost certainly the NPP rattle. My dealer warranty-replaced the entire exhaust... it's better but still does it, especially in touring mode. Just sucks.
~ Ironhide
2018 SS 1LE Nightfall Grey |
03-11-2018, 11:38 AM | #14 |
Just pull the fuse and it is 100% fixed. I know it will be louder but then again it is a sports car...
