Old 10-06-2017, 03:31 PM   #1
asthmamax11
asthmamax11's Avatar
Heartbeat is installed
Just Heartbeat and roto fab air intake
Stock it put down 415/409 as seen on graph
Heartbeat and roto fab gave serious gains
Feels awesome. Very fast.
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-06-2017, 04:34 PM   #2
laynlo15
Drives: 2022 Lt1 A10
Your welcome, glad they got it done for you. Great numbers and you'll need new rear tires soon.
Old 10-06-2017, 09:51 PM   #3
asthmamax11
I'm glad I took your advice and went with Magnuson. The fitment and quality of parts is amazing.
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-06-2017, 10:11 PM   #4
laynlo15
No problem, I was glad to help. I knew you wouldn't be disappointed.
Old 10-07-2017, 03:43 AM   #5
AxiomVerge
AxiomVerge's Avatar
Drives: 2017 Mosaic Black M6 1SS Vert
Is it the Magnusson tune or a custom one?
Sent from my SM-G935T using Tapatalk
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab
Previous:
2008 Corvette Convertible
2007 Pontiac Solstice GXP
AxiomVerge is offline   Reply With Quote
Old 10-07-2017, 08:51 AM   #6
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
Wow.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 10-07-2017, 09:16 AM   #7
oldman
Drives: SS 6 speed of course
really nice dyno and a a good NA to boost comparison. Is this dyno is SAE or STD? can't see the top right of the dyno.
Old 10-07-2017, 02:24 PM   #8
asthmamax11
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-07-2017, 03:07 PM   #9
laynlo15
I don't think the handheld will make that kinda power. Custom tune for sure.
Old 10-07-2017, 03:30 PM   #10
asthmamax11
Greg
What made you decide to get the methanol injection ?
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-07-2017, 06:28 PM   #11
AxiomVerge
AxiomVerge's Avatar
Here was mine... also maggie + rotofab, custom tune, nothing else. M6. 583 rwhp, 552 torque, up from 374 hp. DA should be around 3849 feet.
Previous:
Old 10-07-2017, 07:47 PM   #12
laynlo15
Both are great numbers. I decided to run the Meth/Water injection because it is so hot here in Missouri in the summer. It does help down track as you can see I've run 136 mph a couple weeks ago at Gateway. I think I'll be able to run less Meth/water as it cools off. I run a lot of timing compared to a stock Maggie(7 degrees), Plus I run 80 mm pulley compared to the stock 98 or 95 that comes with the kit. Stock boost is 7 to 8 lbs and I run about 12. So more fuel is good with that much timing, can't go lean.
Old 10-07-2017, 08:39 PM   #13
oldman
I assume this is an SAE dyno run, what would be interesting is to see the two runs as measured (actual HP to the roller), with your DA. My gut feeling is the blower is making even more HP over NA.
Old 10-07-2017, 08:52 PM   #14
AxiomVerge
AxiomVerge's Avatar
Yeah, I'm out of town so I can't check if it's SAE. The weather also changed over the days it took to install... I think the DA was worse in the first run, then had some rare rain and the garage got cooler at the 2nd run.
Previous:
