Old 10-06-2017, 11:01 AM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Clutch pedal
looking for some help, on my 2016 2ss Clutch pedal goes down to the floor, but still works, if i pump it up it comes back for one or two times then back down, has any one had this happen, car is not modded as far as power adders, new TB to fix its driving problems, car has less the 12K in MI.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-06-2017, 12:16 PM   #2
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
Originally Posted by 2SSRS@Gen5diy View Post
looking for some help, on my 2016 2ss Clutch peddle goes down to the floor, but still works, if i pump it up it comes back for one or two times then back down, has any one had this happen, car is not modded as far as power adders, new TB to fix its driving problems, car has less the 12K in MI.
i'm confused.. clutch pedal goes to floor if you push it to the floor = NORMAL
are you saying it just falls to the floor all by itself?
are you saying it stays on the floor after you lift your foot off the pedal?
pls elaborate.
crazydmc is offline   Reply With Quote
Old 10-06-2017, 12:55 PM   #3
2SSRS@Gen5diy
My bad, the Clutch pedal before today, will release at the top with in 1 IN of travel, but today it goes to the floor and with in the last 1In it will release, there is a lot of travel with no engagement of the Clutch, but if i pump the pedal 3 or 4 times it goes back to the top, for a short time.
Old 10-07-2017, 01:29 AM   #4
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Clutch Master Cylinder
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
