Old 10-04-2017, 02:40 PM   #1
GroundhogSS
GroundhogSS's Avatar
Running wires from under hood to cabin
I've seen mention in several threads about getting wires from the under-hood fuse box into the cabin for various components. Has anyone found a good solution? I was looking at the rubber plug that is at the base of the A pillar just above the top door hinge. It looks like it would allow access behind the kick panel on either side. The plug pops right out and could be cut to pass wires through and then sealed with some silicone. There is some sound deadening material under the fender that could be pushed aside to run wires. Would this be a good solution?
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 10-04-2017, 02:56 PM   #2
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Does the SS have a cover where the V6 has the sound tube or is that just not provisioned at all ? That seems like an ideal spot to send wires if you had access to that opening.
Old 10-04-2017, 03:10 PM   #3
Burly
Burly's Avatar
I run stuff from rear under carpet to cabin. There are some body plugs on trunk floor that drilled through. Didn't want wires seen/exposed under hood.
Burly is offline   Reply With Quote
Old 10-04-2017, 04:00 PM   #4
cellsafemode
he's asking about under the hood though. Not the trunk.
Old 10-04-2017, 04:05 PM   #5
GroundhogSS
I'll put the wires in split loom to keep them neat and tied up out of the way. I'm just wanting to find out if this is a good access point.
The SS has the sound tube also. I haven't removed it yet.
Richard
#TeamBeckyD
Old 10-04-2017, 04:16 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Attachment 900222
That one works good, have it in our 2SS.
P.S. comes out the passenger kick panel
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-10-2017, 02:11 PM   #7
GroundhogSS
Thanks. That's what I thought but wanted to be sure.
Richard
#TeamBeckyD
Old 10-10-2017, 02:15 PM   #8
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I used the sound tube when wiring in my jammer.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
