Old 10-02-2017, 08:23 PM   #1
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
BMR Cradle Braces
Has anyone done this and tracked their car before and after?
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 10-18-2017, 11:29 AM   #2
lokitwitch04
Drives: 2017 Camaro SS 2SS
I want to know this also, as I want to buy one in the near future.
lokitwitch04 is offline   Reply With Quote
Old 08-06-2018, 12:47 PM   #3
Black Hole
Drives: 2017 2SS Redline
bump
Black Hole is offline   Reply With Quote
Old 08-06-2018, 03:41 PM   #4
lokitwitch04
Originally Posted by Black Hole View Post
bump
I ended up buying both, front and rear cradle braces, and it illuminated my wheel hop on the stock wheels and tires. I have 17" race stars with MT ET street R's and it seems to plant those well also. Also, I had the diff groan before I put these parts on and now I don't. It did not make the car ride stiffer, at least not in my opinion.
Old 08-06-2018, 07:58 PM   #5
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I thought the braces didnt fit the 1LE
Pollock is offline   Reply With Quote
Old 08-07-2018, 08:42 AM   #6
lokitwitch04
Is there a difference in the rear cradle? I think only the sway bars are different.
Old 08-07-2018, 10:04 AM   #7
Pollock
LT4 M6
Pollock's Avatar
Its says on thier website
***NOTE: This part is not compatible with ZL1 or other models equipped with Electronic differential***
And why the rear brace wont work I have no idea.
Old 08-08-2018, 09:13 AM   #8
lokitwitch04
That's strange. it doesn't even come close to the diff.
Old 08-08-2018, 09:14 AM   #9
lokitwitch04
Sorry its upside down. I don't know how to fix it.
Old 08-08-2018, 10:00 AM   #10
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I think the eLSD has something on the factory crossmember right near where the BMR brace passes by the center.
'18 1SS 1LE Black, PDR
Old 08-08-2018, 01:04 PM   #11
Pollock
LT4 M6
Pollock's Avatar
Is yours a 1LE or a regular SS. Correct me if I am wrong but the 1LE has the same rearend as the ZL1.
Old 08-08-2018, 01:48 PM   #12
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
Yeah I think at least 1 of the mounting points BMR would have you use is occupied.
You could always try a longer bolt or some other solution, but something tells me BMR would be selling the specific part for the eLSD application if it were that easy.
S2K+1LE is offline   Reply With Quote
Old 08-14-2018, 12:36 PM   #13
Black Hole
I am struggling with keeping the tires from spinning at launch running 305/35/20 ET Streets - minor spin compared to prior tires, but I still can't launch the car consistently. I don't have any wheel hop issues so not sure if these would help my situation.
Old 08-14-2018, 08:37 PM   #14
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
Flipped.
Uncle Sam is offline   Reply With Quote
