Old 10-01-2017, 10:56 PM   #1
brook
Drives: 2017 camaro ss
Question Torque converter
I have a 2017 camaro ss, my car has been vibrating at different speeds. Took into dealership and they said they needed to drain all the transmission fluid and change filters and it should stop. If that didn't work after driving it for 200 miles they would have to change the torque converter. I only have twelve thousand miles on my car. Has anybody else had this problem?
brook is offline   Reply With Quote
Old 10-01-2017, 11:04 PM   #2
grampa_ss
grampa_ss's Avatar
More than we care to count. Do some searching. There's even a poll.
Old 10-01-2017, 11:07 PM   #3
n813ca
Drives: 2106 SS
Fixed mine
Sent from my SM-G935V using Tapatalk
n813ca is offline   Reply With Quote
Old 10-01-2017, 11:46 PM   #4
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Technical Camaro Topics
Camaro Issues / Problems | Warranty Discussions | TSB and Recalls (5 Viewing)
Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions.
http://www.camaro6.com/forums/forumdisplay.php?f=257
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 10-02-2017, 08:47 AM   #5
init4fun
Drives: 2017 50th Anniversary
A new converter and fluid flush fixed mine. I only had about 1200 mile son it at the time.
init4fun is offline   Reply With Quote
Old 10-02-2017, 08:53 AM   #6
AmericanMike
AmericanMike's Avatar
Drives: 2017 Camaro SS FIFTY
I am getting the shimmy and the bouncing tach at 3300 miles. Will be calling for an appointment this week.
AmericanMike is offline   Reply With Quote
Old 10-02-2017, 11:27 AM   #7
Spartan268
Spartan268's Avatar
Drives: HB 2SS
I think this is happening to me too. But more at low RPMs like when it's at 1K in V4 mode. Definitely a known issue, typically known to be comparable to driving over rumble strips. I'm waiting for it to be more apparent so I can repeat the issue in front of a tech and get my shizz flushed out
Spartan268 is offline   Reply With Quote
Old 10-02-2017, 12:03 PM   #8
BadBowtieProductions
Check me out on YouTube!
BadBowtieProductions's Avatar
Drives: 2016 Camaro SS
Just had the flush done on mine, seems to have done the trick.
2016 Camaro SS - A8, NPP, 2SS, Nightfall Gray Metallic
11.68 @ 118 - CAI Intake - TSP 2" Longtubes - DSX Tuning Flex Fuel - DSX Tuned
11.91 @ 117 - CAI intake only
11.99 @ 117 - STOCK 1/4 mile
410 RWHP / 424 RWTQ - STOCK Dyno
YouTube Channel: BadBowtieProductions
BadBowtieProductions is offline   Reply With Quote
Old 10-02-2017, 01:22 PM   #9
dviper42
dviper42's Avatar
Drives: Man
Send a message via ICQ to dviper42 Send a message via AIM to dviper42 Send a message via Yahoo to dviper42 Send a message via Skype™ to dviper42
Talking Camaro 2016 2SS A8, NAV, NPP Yellow
At 11000 miles I had a shutter between 40 and 70mph. I thought it was the tires so I replaced the one that I fixed a flat with a plug then checked my alignment they claimed my alignment was off, still did not fix it.
So I went to a different dealer they had their Camaro technician look at it. He said he felt the shutter. So they did the 3 drain refiled and filter, reprogram the tranny thing. They had it for 3 days. When I picked it up it felt like it had more power and was very responsive. The best thing I ever done. Take it to the right technician that is the answer. My car runs like hell on wheels now.
dviper42 is offline   Reply With Quote
Old 10-02-2017, 01:45 PM   #10
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Pretty common problem on the auto c7 vette as well.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 10-02-2017, 02:08 PM   #11
camaro5
camaro5's Avatar
Yes. And apparently the A10 will not fit the C7.
C8's right around the corner.
STANDARD DISCLAIMER
Old 10-02-2017, 03:16 PM   #12
Torquem
Bannable
Torquem's Avatar
Yeah I've heard conflicting things about that. GM touts that the A10 is the same size as the A8, but then says it wont fit the C7 lol.
Old 10-02-2017, 03:23 PM   #13
17txcamaross
Drives: 2017 Camaro 2SS
I wish for my sake flushing the fluids would have corrected my transmission shutter.
I had mine flushed about 3-4k miles. Now I am at approx. 8k miles and the shutter is back. I have plans to get the car to a dealer, however, Houston has zero loaner vehicles available and the Camaro is my daily.
Hopefully once the torque converter is replaced my problems will be corrected...I don't believe it is a true fix though. My guess is all these "fixes" are solely band-aides until the newly installed torque converter fails.
We will see and hopefully I can go further than 3k miles without needing to put the Camaro is the shop this time.
17txcamaross is offline   Reply With Quote
Old 10-02-2017, 05:06 PM   #14
gw6211
gw6211's Avatar
Drives: 2016 2SS
mine did it around 12k miles i think, took it in and the dealer replaced it. Now i have 19k miles and the replacement converter is doing it.
Gonna go back for a second one at some point.
gw6211 is offline   Reply With Quote
