Old 09-28-2017, 04:16 PM   #1
retmil
Drives: 2022 Wild Cherry SS
PowerStop Brake Pads
Has anyone who installed the Z26 pads had any issue with brake squeal? Thinking about replacing my '17SS OEM pads and don't want to deal with the squealing. Thanks.
retmil is offline   Reply With Quote
Old 09-28-2017, 04:35 PM   #2
JeromeS13
Drives: 2017 1SS/1LE
None. Practically no dust and no noise.
Old 09-28-2017, 04:37 PM   #3
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
I have a 17 SS as well. Zero noise from the pads and yes, virtually zero dust. I love the PowerStop pads!
Here is another post from me regarding my experience with the pads.
http://www.camaro6.com/forums/showpo...1&postcount=17
ride98red is offline   Reply With Quote
Old 09-28-2017, 05:08 PM   #4
retmil
Thanks for the replies!
Old 09-28-2017, 05:53 PM   #5
thundercrakcer
thundercrakcer's Avatar
Drives: Summit White 2SS, M6
I do actually, but its only because the pads and rotor are cold in the morning. I park underground and the sequel only lasts for about two brake applications. Once warmed up nothing.
thundercrakcer is offline   Reply With Quote
Old 09-28-2017, 06:01 PM   #6
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I did mine, did the rotor prep and put them on and no noise and no dust, and worth the money spent.
warren3537 is offline   Reply With Quote
Old 09-28-2017, 08:31 PM   #7
parbreak
Drives: 2017 50th Camaro SS
Put Powerstop on my 17 and it was the best decision ever. Mated them up with drilled and slotted rotors. I get a tiny bit of squeal first thing in the morning but the lack of dust far makes up for that.
parbreak is offline   Reply With Quote
Old 09-29-2017, 10:51 AM   #8
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
I have a constant grinding noise, even not braking. Maybe because I didn't break them in properly.
Chevy Service said its normal for ceramic brake pads...
ajp is offline   Reply With Quote
Old 09-29-2017, 01:42 PM   #9
JeromeS13
I would have someone else inspect them.
Old 09-29-2017, 02:56 PM   #10
warren3537
warren3537's Avatar
I would make sure that everything is bolted up properly and that nothing is loose or bent.
Old 09-29-2017, 08:30 PM   #11
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Zero squeel on my Z26 fronts. And very little dust. Certainly no grinding noises!
BrianL is offline   Reply With Quote
Old 09-30-2017, 03:59 AM   #12
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Put some on the rears for a trial run. Won't believe the difference in dust. No squealing or grinding for me
CruzySS is offline   Reply With Quote
