Old 09-27-2017, 08:11 AM   #1
soldes
Drives: car
what's your oil pressure
Hello Guys,
as the tittle says, did anyone notice a similar behaviour of the oil gauge? I know it's just a representation but I assume it's based on the oil pressure sensor readings.
At cruise the oil pressure is around the 40 psi (depending on oil temp etc)
what worries me a bit is that during acceleration from 0 or from cruising the gauge pegs out at 80psi even with minor throttle input.
I just noticed this recently as I went from technology to the standard layout.
Someone asked a similar question before but got no answer, so I'm curious what you are all reading.
Thanks,
Nick
soldes is offline   Reply With Quote
Old 09-29-2017, 03:01 AM   #2
soldes
Drives: car
No one has ever looked at their oil gauge?
Old 09-29-2017, 06:27 AM   #3
ag1leSS
Drives: 17 Hyper Blue SS 1LE
I don't believe I've ever seen mine go to 80. Maybe much less over 50 and that seems to happen when I'm braking
ag1leSS is offline   Reply With Quote
Old 09-29-2017, 08:25 AM   #4
HyperJake
HyperJake's Avatar
Drives: 2016 Hyper Blue 3.6L 2LT
mine pegs out at 80 too in WOT in my 3.6L... I was hoping you'd gotten some response on this so it could ease my worries a bit as well...
HyperJake is offline   Reply With Quote
Old 09-29-2017, 09:05 AM   #5
Saybo
Saybo's Avatar
Drives: 2018 SS 1LE
My v8 hardly gets over 50 but I could imagine a smaller displacement engine having a higher pressure. When I had my Focus ST I would get over 70psi if I went WOT before the oil came 100% to temp. High oil pressure isn't the worst thing in the world. It's low pressure you need to worry about.
Saybo is offline   Reply With Quote
Old 09-29-2017, 11:31 PM   #6
ag1leSS
I just realized this was in the the i4 turbo forum. Lol
Old 09-30-2017, 09:18 AM   #7
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Originally Posted by soldes View Post
Hello Guys,
Thanks,
Nick
If I remember correctly mine does the same. I'll check after awhile and let ya know.
Old 09-30-2017, 01:44 PM   #8
Michigan1LTRS
Blessed ❤️
Ok, fully warmed up the oil pressure varies between 34 at idle to 75 depending on rpms. Before fully warmed up i saw some pressures in the 80's at higher rpms. I'm not sure about full throttle I didn't do that testing.
Old 10-01-2017, 06:10 AM   #9
soldes
Drives: car
Thanks guys, I guess it's normal !
Nick
Old 10-01-2017, 06:07 PM   #10
Camar05
Camar05's Avatar
Drives: NGM '16 2LT A8
Yes, apparently it's normal. I have the V6 and when I plugged my scanner in to see what the actual oil pressure was if I remember correctly, it was at 110
Camar05 is offline   Reply With Quote
