Old 09-26-2017, 09:21 PM   #1
GM Lifer
GM Lifer's Avatar
Drives: 2016 Camaro SS in Red Hot
Peeling Steering Wheel
Noticed this afternoon that the flat black paint on the little plastic piece at the bottom of my SS's steering wheel is peeling in spots. Car's about 18 months old. Anyone seen this? Can't decide if it's worth fixing. Love the steering wheel otherwise. Where the flat black came off, it's shiny underneath. You can see in the photo a few other little bubbles that are about to peel.
GM Lifer is offline   Reply With Quote
Old 09-26-2017, 10:28 PM   #2
16silverSS
16silverSS's Avatar
Drives: 2016 Camaro SS 2ss A8
My cars doing the same thing. Cars had lots of problems. Motor failure at 18,500 miles due to afm lifter. A8 has been flushed per Gm tsb. Still shifting hard and erratically and shutters hard. Cars going back into the dealer next week for transmission lol. I’m going to a lemon law lawyer after this visit. I’m sure I have a strong case.
16silverSS is offline   Reply With Quote
Old 09-26-2017, 10:37 PM   #3
Cameron27
Drives: 2015 2SS
Cameron27 is offline   Reply With Quote
Old 09-27-2017, 12:01 AM   #4
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Not just chevy, my MINI had the same issue with the satin black coating on the steering wheel trim. Personally, I believe its a chemical reaction between some cleaning product and the surface. Once compromised, the surface bubbles and peels, like plasti-dip. What I would do in your situation is:
1.) Remove the trim.
2.) remove the SS badge, or tape it off.
3.) Sand finish through varying grades of sandpaper.
4.) Finish the surface off with 1000 grit sandpaper, leaving a satin finish in the actual plastic, something that would never peel off.
The dealer should fix the issue under the warranty, but you may end up leaving with a cracked windshield due to common dealership negligence.
soloknight6 is offline   Reply With Quote
Old 09-27-2017, 12:52 AM   #5
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
I have a spare if you want it
aronSlusa is offline   Reply With Quote
Old 09-27-2017, 09:40 AM   #6
GM Lifer
GM Lifer's Avatar
I've never actually used a chemical to clean the wheel--just wiped it with a cloth. As for removing the piece, any idea how to get it off? I'd hate to start prying on it and bust it. And I agree about the dealer--the cure may be worse than the disease.
Old 09-27-2017, 09:41 AM   #7
GM Lifer
GM Lifer's Avatar
Thanks. You have an entire wheel, or just this trim piece?
Old 09-27-2017, 12:24 PM   #8
Pfuqu2ss
Drives: Fuqing car
Mine did that too. I took it off, peeled the rest and painted body color.
Pfuqu2ss is offline   Reply With Quote
Old 09-27-2017, 02:03 PM   #9
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Mine did it too. I think that little square piece of plastic pops off and can be replaced without needing a whole new wheel, but I haven't tried.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 09-27-2017, 02:45 PM   #10
Marktrav44
Marktrav44's Avatar
Drives: 2016 Chevy Camaro 2ss Red Hot
This is correct, its just a press fit.
Marktrav44 is offline   Reply With Quote
Old 09-27-2017, 02:47 PM   #11
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Thanks
Old 09-27-2017, 02:48 PM   #12
NightSkyCode
Owned gen 4, 5 and 6
NightSkyCode's Avatar
Drives: 2017 Camaro 2SS
You can order the part for about 30 bucks. Id just pop that off with a plastic ply and pop a new one on. simple. Go to dealer and show them which part you want to order.
2017 2SS, Mosaic black <3, NPP Exhaust, MRC, GM CAI, Loaded.
NightSkyCode is offline   Reply With Quote
Old 09-27-2017, 03:46 PM   #13
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
The scary part is it's the same material they used throughout the dash
pjz1082 is offline   Reply With Quote
Old 09-27-2017, 05:18 PM   #14
Cameron27
Drives: 2015 2SS
