09-26-2017, 06:59 PM | #1 |
Drives: 50 ann. Rs, V6, sunroof, nav, spl Join Date: Aug 2016
Location: Rochester NY way upstate 3 hours from Toronto on Lake Ontario
What If
What if this happened to you? It happened to me. Just a few days after my one year anniversary of taking delivery, I went over a curb when turning.I thought only the tire went over the curb. When I got home and checked it out ,damage was done to the wheel (scratched and gouged in one spot) that went over the curb. Would you have the wheel repaired (about 1/3 of the cost of a new wheel) or would you order a new wheel from the dealer for $640.00. (installed) I have a 50th anniversary so I only have one wheel choice. I'm just thinking of getting a new wheel (hefty price to pay but I might bite the bullet) because it is a 50th anniversary and I try very hard to keep the Camaro looking new. Just wondering what people thought. I have no technical or mechanical abilities to speak of.
09-26-2017, 07:32 PM | #2 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Let's see a pic of the wheel. Why not have it repaired if you can, I once had curb rash repaired on a wheel and it looked new afterwards. Use the extra money for another mod.
09-26-2017, 07:42 PM | #3 |
Drives: 2016 Mosaic Black 2SS, NPP, A8. Join Date: Jun 2016
09-26-2017, 07:47 PM | #4 |
Drives: 2017 2SS black on black on black. Join Date: May 2017
I would look it over very well with the tire off. Check for cracks and if bent and how much material got gouged out.
And see if possible to do a valid repair. As 1hpRush said, they look like new when repaired. and I believe the repair is warrantied. Sorry to hear about your brush with a curb. |
09-26-2017, 08:02 PM | #5 |
Have the tire thoroughly inspected for internal damage. If the wheel is damaged at the mating bead, cracked, out of round, I'd seriously consider a new wheel, but I tend to be very cautious. High speed blow outs have a way doing that...
09-26-2017, 09:14 PM | #6 |
Drives: S O L D Join Date: Aug 2016
+2.....
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
09-26-2017, 10:25 PM | #7 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
09-26-2017, 11:23 PM | #8 |
Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
+4.. Lets see the wheel.
I have a small damage in one of my wheels. It is not noticeable until closely seen, so decided to leave it as it is.
2016 1LT RS Summit White M6 10/2/2016 - 3 Miles on ODO - Delivered 11/1/2016 - All around light Black out kit from Phastek 11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com 12/16/16 - 977 Miles. Borla S-type Axleback Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED |
09-27-2017, 12:08 AM | #9 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Should you want to try to fix it yourself:
Use the Dremel attachment #952 cone shaped aluminum oxide grinding stone and grind down the burrs. Use the Dremel attachment #413 sanding disks and try to round out the gouge Build up the rim edge with metal filler. Wet sand with sandpaper grit 1200 then 2000. Clean it up and paint it with wheel paint or touch up paint that matches the color.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
09-27-2017, 12:36 AM | #10 |
Drives: 2015 2SS Join Date: Aug 2017
09-27-2017, 07:41 AM | #11 |
Drives: Me: '16 2SS yellow, Wife: '16 1SS Join Date: Feb 2016
its personal opinion. But if you believe it compromises the wheel\tire in any way then I would say replace it. Wouldn't you want that peace of mind driving 100+ down the interstate and wondering if the wheel "repair" was enough??
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque |
09-27-2017, 08:13 AM | #12 |
Drives: . Join Date: Jul 2017
Check your vehicle warranties. When I bought my Camaro from the dealer, I added Rim and Tire protection to the warranty.
09-27-2017, 09:38 AM | #13 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I was told that if it still holds air, then the damage is NOT covered. AMHIKT. |
09-27-2017, 12:32 PM | #14 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I also own a 50th anniversary edition. I had damage on the driver side front and rear wheels from something that scratched both of them on the same day at the same time. I still don't know what it was, but it caused semi-circular scratches on both wheels. When I found out how much it's was going to cost to replace them, it was a no-brainer. I had them repaired for $110 each.
Unfortunately, because of the unique machined finish on the surface of the 50th anniversary wheels, when you have them repaired, they won't be able to replicate that. But that is so hard to see unless you are about an inch or so away from the wheel, and it doesn't really affect the overall look. Only I know that it's not the same as the original finish. It bugs me a bit, but not enough to spend the money to buy new wheels...at least not yet!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
Tags |
50th anniversary, wheel damage |
