Old 09-26-2017, 02:06 PM   #1
zryan
zryan's Avatar
Drives: 1973 z28 Rs, 2018 SS 1LE
"Service Rear Diff" Pop Up Message 18' 1ss 1le
I have a brand new 2018 1ss 1le with around 1,600 miles. Almost every time I get hot and heavy with the gas pedal and push the car I get this warning. I have replaced the fluid in the differential but nothing else. Without fail every time I drive "passionately" this warning pops up. Is anyone else having a similar issue?
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
zryan is offline   Reply With Quote
Old 09-26-2017, 07:18 PM   #2
TJay74
Nope, so I would take it to the dealer as it sounds like something is going on with the rear diff.
Old 09-28-2017, 05:15 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Was this a DIY diff fluid change?
Confucius say: operator error number one problem.
Old 10-01-2017, 11:28 AM   #4
zryan
zryan's Avatar
Last time I took it to the dealer I had them change the rear differential fluid. Basically every time the tires get loose it flashes on and I just dismiss it. I guess it might be time to take it in.
Old 10-03-2017, 10:06 AM   #5
zryan
zryan's Avatar
Usually happens after losing traction a bunch of times or hauling ass through a long windy road. No solution thus far. Dealer is stumped.
Old 10-15-2017, 03:15 PM   #6
rootus
Drives: 2018 HBM SS 1LE
Well that sucks, is it still a problem for you. I'm fast approaching 1500 miles on your 'brother' car and after the fluid changes I'm probably going to drive the snot out of it for a while . Not that I've been perfect during break-in, but the few times I've let it rev above 4K makes me want to spend a lot more time up there...
How is your car otherwise zryan? I've had several of the 'typical' problems already with mine. Left endlink has come loose on three separate occasions (every ~400 miles, twice for the bottom nut, once for the top), wheel ticking, NPP valves rattling. Nothing I'm going to bother with the dealer to fix, loctite for the endlinks, grease for the wheel tick, epoxy eventually (fuse pull for now) for the NPP valves. I love the car but dang, I do wonder why GM has trouble with the easy stuff.
rootus is offline   Reply With Quote
Old 10-24-2017, 12:56 PM   #7
zryan
zryan's Avatar
My car is holding up fine, they gave my computer an update which fixed the "service rear diff" issue. I've had the sway-bar issue but that was rectified as well. No other issue although I do hear a ticking type noise and am wondering what that is. I hear it when I'm close to other cars or walls and at lower RPM. Other than that the car is brilliant.
Old 01-07-2018, 01:43 PM   #8
SaphfireSS
Drives: 2017 Camaro 1LE SS
You don't need "grease" for the wheel tick. Just make sure your lug nuts are torqued to 140 ft. lbs. That is probably why it keeps coming back if you're greasing them. They require no lubricant.
SaphfireSS is offline   Reply With Quote
Old 01-25-2018, 02:02 PM   #9
zryan
zryan's Avatar
Update: Despite Chevy dealership efforts to update the computer failed. Car is completely fine but the message still pops up.
Old 01-25-2018, 02:45 PM   #10
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
I may have misunderstood what you wrote. When did this start happening? After you changed the fluid, or at some point before? If it was before, at about what mileage? Thanks.
torqueaddict is offline   Reply With Quote
Old 03-20-2018, 04:49 PM   #11
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
i just got this message today..
370 miles on the vehicle and totally following break in procedure
it was cold out......
haven't seen message again today...
no check engine light...
I'm going to ignore unless it comes back...
i plan on doing diff fluid change at 1500 miles...
also noticed what sound like a small exhaust leak....i can hear it when driving sounds like front driver side..
biker2k is offline   Reply With Quote
Old 03-21-2018, 02:57 PM   #12
modru2004
Drives: 2018 2ss
well you can test it by spinning the tires. the 1le has an electronically controlled diff. its likely failing to engage for whatever reason.
modru2004 is offline   Reply With Quote
1le, 1ss, rear differential, service rear diff, warning message
