Old 09-25-2017, 11:19 PM   #1
ScottMZ3
ScottMZ3's Avatar
Drives: 2018 ZL1 A10, 2019 BMW X5
HUD and the front end of the car...
Only had the ZL1 a couple days (most amazing car I have ever driven, hands down)...however its taking a little getting used to parking the car. The ZL1's hood is much longer, wider, and higher than the BMWs I have been driving and I don't want to take any chances hitting that splitter on a curb (I classify curbs in the same category as the plague)! So last night I had my wife stand right up against the front of the car after I pulled in the garage. That way I could get a visual of just how far out there the hood went.
Well I discovered something pretty darn cool! The distance that the HUD appears to be out in front of the windshield ended up being EXACTLY where the front of the car is! So you can actually use the HUD as a gauge for parking! Used it that way today and it worked like a charm!
Maybe the engineers intended it to be that way? Perhaps its common knowledge? In any case it was news to me and I find it VERY useful!! Hope it helps some of you out there as well.
2018 Nightfall Gray Metallic Camaro ZL1 - A10
Purchased 9/23/2017
ScottMZ3 is offline   Reply With Quote
Old 09-25-2017, 11:21 PM   #2
Thirty3
Drives: SS 1LE
Or just back into spots...but your find sounds helpful too!
2018 SS 1LE
Thirty3 is offline   Reply With Quote
Old 09-25-2017, 11:21 PM   #3
ScottMZ3
ScottMZ3's Avatar
LOL...yeah that too.
Purchased 9/23/2017
Old 09-26-2017, 09:40 AM   #4
Jmueller
Drives: 2017 ZL1 A10 Nightfall Gray
But you can move the HUD up and down. Would that not change your visual reference? The obvious response to this question is: "don't move the HUD." But I would forever be fearful that the HUD got moved. Once you drive the car enough, you can place the front of the car when your parking. I tend to back into spots though.
Jmueller is offline   Reply With Quote
Old 09-26-2017, 09:42 AM   #5
JeromeS13
Drives: 2017 1SS/1LE
Yes, moving the HUD and/or your seat changes this point of reference. However, that works in your advantage once you get both in your preferred locations.
Old 09-26-2017, 10:16 AM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by ScottMZ3 View Post
...Maybe the engineers intended it to be that way? ....
It's probable. They were able to put the focal length anywhere they chose. Having it way off in the distance isn't great because you'd focus on that instead of the road. Having it at the nose of the car means you still have to adjust your eyes focal distance, but not as much as the cluster, so it's marginally quicker to view. It's also convenient for knowing where the nose is. Win/win.
Old 09-26-2017, 12:30 PM   #7
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I back in and lower the mirror if there is a curb along the side.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 09-26-2017, 08:37 PM   #8
Smuuth
Smuuth's Avatar
Drives: 2017 Hyper Blue Metallic ZL1
As do I - I have the mirrors set to lower the angle when in reverse.
Smuuth is offline   Reply With Quote
Old 09-26-2017, 08:54 PM   #9
WhiteBoy18
WhiteBoy18's Avatar
Drives: 2018 ZL1 Summit White M6
Good info, I'll have to try it out! Also you can wire up a front camera for about $60 if you want to eliminate the guessing game.
WhiteBoy18 is offline   Reply With Quote
Old 09-27-2017, 08:11 AM   #10
utsteve98
Drives: 2018 ZL1 1LE, 2017 Ford Raptor
These cars were designed to be backed in.
utsteve98 is offline   Reply With Quote
Old 09-27-2017, 08:44 AM   #11
WhyUMad1LE
Drives: 17 SS 1LE
Parking would be a lot easier with a front camera like what's available on the Vette and ATS. However in the absence of that, this sounds like a good barometer so I will try it out.
