Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 09-21-2017, 02:08 PM   #1
anjoeche
Drives: 2017 Chevrolet Camaro 2SS 6M (RED)
Square tire/wheel setup 2017 2SS
I have a potentially dumb question. I could not find an answer or a thread that could answer it. I'm about to install 245/40/20 and 8.5 all 4 sides to replace stock wheel/tires. Will this be possible without sacrificing a significant amount of performance. This is for a DD btw.
anjoeche is offline   Reply With Quote
Old 09-21-2017, 02:31 PM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
At CamaroFest7, Al O. explained that they tried several combinations of square and staggered setups and the staggered setup performed the best on the 6th gen chassis. However, it probably depends on how you define significant - I doubt you'll get lap time #s from him if that's what you're looking for. If you do change the rear tire from the stock size, check the diameter to make sure it's very close to avoid any issues with ABS or stability control.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 09-21-2017, 02:47 PM   #3
anjoeche
The new ones are essentially the same exact size as the stock front tires/Wheels. Not sure if that helps.
